90 gt wont start
  • Thread starter Thread starter scooter_ky
  • Start date Start date Apr 5, 2006
scooter_ky
  • Apr 5, 2006
ok, so i bought a 90 gt body a year ago and have been collecting parts since, finally i get the motor together and put in. it ran it for 30 minutes in the garage but it was running rich, i adjusted the regulator and the fuel pressure wouldnt go below 40 psi with my 255 lph pump, so i swapped out the pump for a new 150 lph fuel pump, now the pressure goes down to 30 psi minimum but the car wouldnt start anymore i adjusted the pressure up high and in between, i even tried puting the 255 pump back in and still wouldnt start. so i checked the spark plugs thinking maybe fouled from where it was running rich, seems to be ok also i checked timing, it was 12* without the spout. so i grabbed the engine start spray and it ran till it burnt out so im getting spark. and suggestions or help at all would be appreciated
here is a list of all the engine mods so you all can see for reference
302 longrod with 289 crank, flat top pistons, 11.5-1 compression, 351 windsor heads ported polished stainless 190 valves, cobra lower intake, gt-40 upper intake with 1" heat spacer, f-303 cam, geardrive, hydraulic roller lifters, roller rockers, underdrive pulley, msd 6al ignition box, msd billet dist, moroso ultra 40 wires, 75mm bbk throttle body, cold air intake, 24# fms injectors, 75mm mass air meter calibrated 24#, bbk advustable fuel regulator with gauge in hood, headman long tube headers, 2.25 exhaust with dual flowmaster 40's and x-pipe, 5 speed tranny 3.73 gears with auburn locker and STOCK computer which i dont know if it would hurt to run
HISSIN50
34
129
Apr 5, 2006
  • Apr 5, 2006
See Jrichker's 'cranks but no start' list for the master checklist. Since not a whole lot of info was given, you can read through it and follow each step till you find the issue.
Good luck.
T
TheUser
1,859
Springfield, MO
Apr 5, 2006
  • Apr 5, 2006
well, if you're getting spark, then you're having fuel problems. I assume you know that though. Are you sure the fuel pump is priming?
I would think you should be able to adjust the pressure how you see fit with either of those pumps; any fuel not used returns to the tank on these cars.
Put your SPOUT back in and see if that helps. The fact that it runs w/ spray most usually indicates a fuel issue though - although my car did similar things when the head gasket was blown.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 5, 2006
  • Apr 5, 2006
As suggested...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
scooter_ky
  • Apr 7, 2006
thanks for the help guys. found out the problem today tho, i drained the tank and put some fresh 91 octane $3. a gallon but she started up just fine and dang it sounds SWEET just need to finish getting the timing and fuel pressure adjusted out and im off to the track
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
  • dan50
  • Jul 18, 2026
dan50
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
