  • SN95 V6 Mustang Tech
95 Issues
  • Thread starter Thread starter Rothrock95
  • Start date Start date Jul 29, 2008
Rothrock95
Florida
Jul 29, 2008
  • Jul 29, 2008
I have a 1995 Mustang with a 3.8L V6. It currently has 157,800 miles on it and is in great condition other than the few problems that I have at the moment. Up until now, I really haven’t had any problems worth mentioning. I’m going to do my best to explain everything as clearly as possible.
Here’s my first issue. If I start my car with the air conditioning turned off, the air works fine. If I start my car with the air turned on, it comes out of the defrost vents on the dash. If I turn my air off while I am driving and then try to turn it back on before I turn my car off, it comes out of the defrost vents again. Sometimes it will be working fine and start to come out of the defrost vents while I’m driving but after about 30 minutes, it will start working properly. I don’t know what could be causing this but it is occurring more and more frequently and it’s essential that I have air conditioning due to the fact that I live in Florida.
Now for the other issue. I’m having acceleration problems as well. Yeah, yeah, I understand that I have a 3.8L so I know it’s not going to get up and go like a GT would. I’ve just been noticing that it has been less responsive than it used to be. I don’t know if that could be due to the fact that it has 157,000 miles on it or if after so many miles it just gets slower. It just doesn’t feel like it has power anymore. From a stoplight, it accelerates very slowly. It used to be slow to come out of first gear since I got it but it would quickly go through the other gears and I would be going 60mph before I knew it. But lately it is slow through all the gears. It takes about 12 seconds for me to get up to speed. Also, if I need to pass someone, it takes about 6 seconds after I push the gas pedal to respond and go into passing gear. I just remember it being more responsive than that. It’s getting to the point where I no longer feel as confident driving on a highway due to my car’s poor acceleration.
I hope I explained all of that clearly. Any help would be greatly appreciated.
Thank you.
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Jul 30, 2008
  • Jul 30, 2008
1st issue is usually a vac leak. The HVAC defaults to floor/defrost with no vacuum. In order to go to the panel vents, vac needs to be applied. There is a line in the center of the dash which draws the flapper to change it. You'll need to poke around and search for it.
2nd issue. When was the last time you did a tune up? New plugs wires. cap rotor, fuel filter, air filter, etc?? Is the check engine light on?
1983 glx
25
  • Aug 27, 2008
Had the same problem with my son Mustang, There is a small vacuum line the runs from a tee on the driver side fender and across firewall, there was a break where it went to a joint, fixed it and works fine.
ChingonStang
308
Dallas, Tejas
Aug 27, 2008
  • Aug 27, 2008
+1 and also on the second issue, when the is the last time you had the transmission serviced?
D
dumbmick
  • Aug 27, 2008
Could be your oxygen sensors are going and/or your cat conv.
Tom
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
SN95 V6 Mustang Tech Mar 20, 2026
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
