97 explorer 302 microsquirt
Sep 20, 2018
25
minnesota
Hey all, I am tuning my v3 microsquirt 97 explorer block, f cam, yellow top stock injectors, fuel pump 300lph, running TFI disty. Fires up idles smooth about 1k any lower it hunts a little. I have auto tune setup and let it tune a bit however my issue is.. The tfi requires 2 power wires. One in Run position another just for cranking. I have a power wire on a switch I use during cranking then turn it off. Then engine runs well with it getting power. Breaks up and misfires when trying to rev with it off.. maybe my main power wire Is weak?
Thanks
-Brian
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
Microsquirt is not the same as MS3. It uses the ms2 firmware files.
The tfi is 'push to start' so the second 12v is forcing the timing to be locked at 10* Or whatever you have the base timing set to.
Did you verify timing with the trigger wizard?
Sep 20, 2018
25
minnesota
Microsquirt v3*
I was running it today. It said 15 btdc in the wizard but should be 10 on the crank. I will go through and adjust that tomorrow
Sep 20, 2018
25
minnesota
I used the trigger wizard and set the timing. Wont run with 20 degrees fixed table but it will idle well at 10. It breaks up and wont rev. With the push to start wire given power it will rev smoothly. What am I doing wrong?
Thanks
-Brian
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
Im sorry i cant really help you with this one not being with the car, post a copy of the tune file so i can take a look at what you have going on
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
no just post a copy of your .msq file for me to look at that will tell me much more than some pictures
Sep 20, 2018
25
minnesota
I removed my lower intake regasket'd her reassembled and fired up with timing fixed at 10* here is the file
THANK YOU!
25
minnesota
#11
hmm I will keep playing with the wizard see if I can get it to sync correctly.. I have my balancer marked with a paint marker. the original markings are pretty much gone... Is it bad to leave it in fixed timing?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
#12
lets try and figure out why its happening... can you get me a datalog of the car running when this happens so i can help troubleshoot?
Sep 20, 2018
25
minnesota
#13
Sure. I will log it and get back tomorrow most likely. It has 2.5 exhaust with spin tech muffler.. had the cops stop by yesterday from a neighbors noise complaint at 2pm... the cop was cool. His jaw dropped when he saw the car and build. Not breaking the law have a good day haha
Sep 20, 2018
25
minnesota
#15
The solid state drive in my d830 Dell took a sh!t today ugggg. Gonna replace the unit and get back to you
Sep 20, 2018
25
minnesota
#16
Currently loading tuner studio Into the new laptop. Going to grab a couple date logs and post them later
25
minnesota
#17
#technical difficulties. I replaced my tuning laptop and I did a lower intake gasket had to retime the motor. I got it fired up idling fine. however my fuel ve table is WAY off... here are a couple logs. I got left the timing fixed.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
#18
In the datalog your MAP signal is not working, it never changes.. If it does it does not change very much... Its reading over 250 KPA so unless your in the center of the earth this is wrong.
Check that the map sensor is calibrated correctly and hooked up right. If this is a micro squirt did you have to rewire the sensor on the firewall to a GM 2bar??
Sep 20, 2018
25
minnesota
#19
How did you know I was in the center of the earth? Haha. I have an aem 3.5 bar. I just got a new pigtail for it. Soldered it in because the ecu wouldn't even boot before. Possible bad sensor?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
7,395
4,294
204
29
Hillsborough county
#20
Possible, like I said check that it is calibrated in the sensor calibration menu under the tools menu.
