was driving to work this morning and then my battery light on the dash came on. Pulled off the freeway a couple miles down the road and my ps was gone as were my power brakes, but engine was still on. when i pulled over, my serpintine belt was destroyed and anti freeze was leaking all over. I assume the anti freeze was leaking due to no water pump to pull it into the engine, seemed to be coming out the cap area.
Anyways, towed the car home. How do i loosen the tension on the belt tensioner so i can put the new belt on? do i use a big screwdriver or bar to lift it up or down so the belt goes on? is it easy or hard to do? Also, do you think there would be any engine damage since it ran a few after the belt broke? my anti freeze over flow is way down, so i have to fill that, should it be fine after i figure out how to get the new belt on?
