  • 1994 - 1995 Specific Tech
A/C Issues... Help??
  • Thread starter Thread starter SableSal
  • Start date Start date Sep 18, 2009
SableSal
295
Fresno, Californ-I-A
Sep 18, 2009
  • Sep 18, 2009
Well, I have a 95GT and the A/C isn't working. Now, I did some trouble shooting and did find that the compressor is not getting any voltage at the clutch coil. Now, what are the possibilities? I did check all fuses and the control unit. All checked good. I know there's a low pressure switch that if bypassed should trigger it on. I've bypassed it, and it's still not getting power. What else could be the problem?
Thanks in advance!
Sal
94GTCoupe
1,412
92
79
CA
Sep 18, 2009
  • Sep 18, 2009
some info here that may help you out alittle.
http://www.stangnet.com/mustang-forums/552622-need-help-ac.html
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 18, 2009
  • Sep 18, 2009
The system really only has one control, and that is the cycle switch located on top of the dryer accumulator. The cycle switch will turn the compressor off if the pressure is too low, or too high. If you unplug the cycle switch and bridge the terminal on the pigtail with a paper clip, the compressor should turn on. If it doesn't turn on, it is most likely the compressor relay that has failed.
Kurt
SableSal
295
Sep 19, 2009
  • Sep 19, 2009
Kurt
I did replace the relay and still nothing. I'm assuming it could be the switch at the receiver drier. Now, there are four wires at that switch. Which do I connect with a jumper wire? I'm thinking on just replacing both switches.
Let me know!
Sal
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 19, 2009
  • Sep 19, 2009
Should be only 2 wires.
Kurt
SableSal
295
Sep 19, 2009
  • Sep 19, 2009
Kurt
That's on the low pressure / Clutch Cycling switch... Hold on. I need to take another look. I think there may be another switch around there. We'll see.
toyman
1,944
54
79
Vernon BC
Sep 19, 2009
  • Sep 19, 2009
At the firewall on top of the condenser. Only two wires and cannot be confused with any thing else in that area.
SableSal
295
Sep 19, 2009
  • Sep 19, 2009
Yeah, I'll try and check it tomorrow. Thanks again guys for the help
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
