A/C works sometimes
  • Thread starter Thread starter f8tlfiveo
  • Start date Start date Aug 11, 2009
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Aug 11, 2009
  • Aug 11, 2009
a/c works sometimes....i am pretty sure it has somthing to do with the wiring because when i turn the a/c switch on the electric fan and compressor doesent always engage...it seems like power is not getting to the compressor or to the fan to tell it to turn on...any help would be greatly appreciated
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 11, 2009
  • Aug 11, 2009
Air conditioning electrical troubleshooting 87-93 Mustangs.
Diagrams courtesy of Tmoss & Stang&2birds
Check out TMoss's diagram I posted. Anytime the clutch is energized, the black/yellow clutch power wire should show 12 volts or whatever the battery voltage is measured at the battery.
Make sure the black ground wire is good, and that it connects to a clean bare metal place on the engine. Measure the voltage between the black/yellow wire and the battery ground cable. Good 12 volts, then you have a bad ground. The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges
No 12 volts on the black/yellow wire, check voltage at the pink/blue wire on the WOT relay: it should be 12 volts. The WOT relay is located under the Mass air meter on the passenger side.
Good 12 volts on the pink/blue wire on the WOT relay, ground the orange/lt blue wire on the WOT relay. Recheck for 12 volts on black/yellow wire. No 12 volts on the black/yellow wire, recheck your ground for the orange/lt blue wire. If it is good, replace the WOT relay.
No 12 volts on the pink/blue wire on the WOT relay, check out the low pressure cutout switch. Look for 12 volts on the green/purple wire.
No 12 volts on the green/purple wire, the A/C control switch is bad or the power to the switch is bad.
The next step is valid only if you are sure there is sufficient refrigerant change to make the system operate. The low pressure switch is supposed to shut off the compressor if the refrigerant charge is low. It does this to protect the compressor, since the refrigerant helps to circulate the oil that lubricates the compressor.
If there is good 12 volts at the green/purple wire, measure the voltage drop across the low pressure cutout switch. With the switch connected, probe the back of the switch connector. Use a pair of paper clips or safety pins to measure the voltage between the green/purple wire & pink/blue wire. Do not connect the voltmeter to ground, just the two wires. This measures the voltage drop across the low pressure cutout switch. You should see less than .75 volts. Less voltage drop is always good, but more voltage drop is bad. More than .75 volts, replace the low pressure cutout switch. It unscrews without draining the system or causing more than a short PIFF of gas escaping. The local auto parts store should have a replacement switch. Inspect the low pressure cutout switch wiring harness contacts before replacing the switch. A replacement pigtail is also available at the local auto parts store.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
87AODGT
373
Toms River, NJ
Aug 11, 2009
  • Aug 11, 2009
another thing is if it's just comin on and off it could possibly use a charge of freon or maybe a new pressure cutoff switch
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Aug 12, 2009
  • Aug 12, 2009
the wires going to the wot relay were melted...replaced them now it works like a dream..
Posted via Mobile Device
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
