  • SN95 4.6L Mustang Tech
alignment didn't last long...
  • Thread starter Thread starter geoffsgt
  • Start date Start date Mar 25, 2007
geoffsgt
176
Baton Rouge, LA
Mar 25, 2007
  • Mar 25, 2007
Had to get new front tires on the GT. They wore real weird cuz my alignment was off a lot. I was also experiencing a slight pull to the right. Got the tires on, and had the alignment done, and it drove straight as an arrow all the way to my parents' house. Drove down their very bumpy driveway (very slowly, as usual). When I left, it was pulling to the right again, about as much as before the alignment. Tested it on multiple streets at multiple speeds, and it was all pretty much the same.
Did my alignment get screwed up already?
the98stang
2,408
Clovis, CA
Mar 25, 2007
  • Mar 25, 2007
Did you drop the car at all?
gtvertsoon
154
Port Tobacco, MD
Mar 25, 2007
  • Mar 25, 2007
Similar thing happened to me. I took the car for an alignment. He gave me the specs before and after and he changed the toe of one front wheel 1 degree and thats it. I think the front tire wear got worse and now I'm going to have to replace my fronts very soon.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 25, 2007
  • Mar 25, 2007
I had to replace two fronts after my spring install. I took it to a shop and he said he adjusted it as far as he could but with the stock plates it just wasn't enough. It wore even worse than before. I installed Maximum Motorsports CC plates and it helped a ton. Went to another shop to get another alighment and it still pulls a bit to the right also but so far it has worn pretty even. I might bring it in to see if they can adjust it a bit more.
the98stang
2,408
Clovis, CA
Mar 26, 2007
  • Mar 26, 2007
You prolly hit a bump and threw off the alignment. It's pretty easier to do with a lowered car.
SilverBullet00
1,150
Wichita, KS
Mar 26, 2007
  • Mar 26, 2007
You should look into getting a lifetime alignment, its worth it!
geoffsgt
176
Baton Rouge, LA
Mar 26, 2007
  • Mar 26, 2007
Car isn't lowered. Stock suspension.
Whats a lifetime alignment? And would it still be lifetime if I modded the suspension afterwards?
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
