ALIGNMENT SPECS!! HEEEEELLLLLPPPPPP!
  • Thread starter Thread starter 66mustanger
  • Start date Start date May 11, 2004
66mustanger
25
mason,ohio
May 11, 2004
  • May 11, 2004
ALIGNMENT SPECS. HEEEELLLLLPPPP!
Im now ready to install my front suspension! My question is, after I bolt on my uppers and lowers w/ spindles, Do I then bolt the tires on and sit the car down on the ground and add weight before I bolt down my strut rods/ bushings and front sway bar? I think I read something a day or to ago about someone doing this. Dont you bolt everything together and try to set your front suspension as close to spec as possible before you let the car down? Im in the dark about this and any advice would be greatly appreciated. Id hate to go a test drive and something is really screwed up and have to take some things back apart!
Thanks and God Bless!
Larry of Mason Ohio.
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
May 11, 2004
  • May 11, 2004
You shouldn't have any problems with bolting this all up while it's in the air with the exception of the sway bar. You can snap the end link bolt if you tighten it up to much before setting it down. Here's a good alignment spec sheet if you guys are interested...
Alignment Science
http://www.fly-ford.com/MustangFords0404-AlignmentScience.html
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
