  • 1994 - 1995 Specific Tech
alternator hitting valve cover
  • Thread starter Thread starter red1995gts
  • Start date Start date Feb 20, 2009
R
red1995gts
42
  • Feb 20, 2009
i got canton aluminum valve covers for my 95 gt and now the alternator is hitting the valve cover. what can i do???????? thanks
Venom351R
4,548
41
98
MAINE
Feb 20, 2009
  • Feb 20, 2009
how bad is it hitting, you can grind it down some
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 20, 2009
  • Feb 20, 2009
I had just a tiny amount of interference with my Fox body VC's
I used one washer on each mounting location to shim the alt out
about 65 thousandths
Grady
R
red1995gts
42
  • Feb 20, 2009
its hitting the electricl conector it needs to go in about a 1/4 of an inch
FlyBy763
439
Palm Bay, FL
Feb 20, 2009
  • Feb 20, 2009
grind alternator, grind valve cover, clearance valve cover, move alternator. About your only options.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 20, 2009
  • Feb 20, 2009
Hot Rodding 101 baby
Just do what ever it takes to make it work
Grady
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 21, 2009
  • Feb 21, 2009
Some valve covers can not be clearance enough. I know the Trick Flow Valve covers fit without clearancing, but there is a good chance you will not be able to get those Canton valve covers to fit no matter what you do. Most of the valve covers out there are designed for 93' and older mustangs where the alternator sits way forward.
Kurt
RIO5.0
6,892
N.H.
Feb 21, 2009
  • Feb 21, 2009
Had that issue before... Best fix was to cut a 1" square out of the VC to give the alt clearance. Used some Aluminum tape on the I.D. to create a concave area for clearance. Skim over that both in and out with some JB weld... Done deal. The repair is buried behind the alt and needs nada...Mines been leak free for 5 yrs...
R
red1995gts
42
  • Feb 21, 2009
do you think putting spacers behind the alt. bracket , powersteerng/ac bracket, and crank pulley will do it?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 21, 2009
#10
  • Feb 21, 2009
  • #10
Sounds like a lot of trouble
You should be able to shorten that electrical bolt a bit
I have wondered if you could clock the alt by a small amount for more room
Just look at the big picture and see what idea you can come up with
You could slot the vc bolt holes ever so slightly for like 1/16th of an inch
Just get creative ... Like Larry Says ... Get er Done
Grady
99FiveOh
2,051
20
99
J-Ville, FL
Feb 21, 2009
#11
  • Feb 21, 2009
  • #11
I also grinded my Fox valve cover down a tad to get the alt to fit properly.
R
red1995gts
42
#12
  • Feb 22, 2009
  • #12
well i put spacers behind both brackets and the the pulleys. i cranked the motor by hand a bunch of times and it seems to be in line. i cant start it yet becasue im waiting on an intake spacer becasue its hitting the valve covers. the gray electrical conector is still rubbing the valve cover a tiny bit. how hot do thy get? do you think it will cvause damage? trhank you
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
D
For Sale 08 Mustang TMI seat covers/foams
  • Don7Up
  • Oct 3, 2026
  • Interior Exterior Parts
Interior Exterior Parts Oct 3, 2026
Don7Up
D
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
