Alternator Question
  • Thread starter Thread starter shlby123
  • Start date Start date Aug 22, 2006
shlby123
579
Dallas
Aug 22, 2006
  • Aug 22, 2006
I was just curious. If my alternator was completely broke or crapped out, would my car even start? how long would it last until it would not start anymore? Theoretically, will just giving my car a little jump from a battery pack work as a temporary reprieve until the part arrives at the house? Just trying to pinpoint if my problem is my alternator or battery itself?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 22, 2006
  • Aug 22, 2006
You can remove the alternator from the car and it will start if the batttery has enough charge.
How long the engine will run on just battery is a big question mark. There are many variables, such as the age of the battery, the current state of charge, and the drain on the battery from supplying power for the ignition, fuel system, computer and accessories.
A failing battery will not provide the power needed to energize the alternator field windings. This will prevent a good alternator from making sufficent power to supply all the needs. The best test is the free one provided by your local auto parts store with their charging system testers. You can pull the alternator and have it tested separately, or the best way to do it is to drive up & have them test the whole system.
D
dec322
401
Bham AL
Aug 22, 2006
  • Aug 22, 2006
The car will start and run even if the alt is not charging. I left my alt unplugged on accident and was confused by the gauge all the way to work. It was reading around 9 so I checked it out at work and saw the problem. Eventually (real quick) the battery will die because the car is running off the battery and not the alternator.
Can't you take the car to an autozone or something and get the battery and alt. checked out?
shlby123
579
Dallas
Aug 22, 2006
  • Aug 22, 2006
Is autozone able to do a test to find out if my alternator is crapped out while the alt. is still in the truck? I have a back up alt...I just do not want to do the swap unless I have to of course.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Aug 22, 2006
  • Aug 22, 2006
Your best bet is to let your fingers do the walking. Pick up the yellow pages and call your local parts stores and see what they can and can't do. Then there will be no surprises when you get there. Just some advise, Hope you get it figured out soon. No fun when the stang is not running right.
HISSIN50
34
129
Aug 22, 2006
  • Aug 22, 2006
FWIW, around here they can dynamically test the charging system (all parts in the car) to see if the alt crapped its pants. I've had this done at CSK.
Good luck.
D
dec322
401
Bham AL
Aug 22, 2006
  • Aug 22, 2006
I think autozone can test while the alt is still in the car.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
