traction lok rebuild kits cost approx. $45 on e-bay use only ford brand. read articles below about traction lok rebuild.
removing the traction lok
select a suitable spot that won't impede normal foot traffic and can be occupied for a couple of days without disturbing. Jack the car up as high as safely possible and support with jackstands (double check stability before crawling under!). I usually support the rear by the subframe connectors; I let the rear down to full shock extension. This gives me quite a bit of room to work on the set-up...Remove the rear wheels and tires, and set aside. Remove the rear sway bar, using 15mm tools (four fasteners) (SN95 note: slide the ABS cables from the ABS brackets, located on the aft (rear) sway bar fasteners; then remove fasteners). With a 1/2" socket and ratchet, remove the three bottom fasteners on the rear cover. Place a drain pan under the cover, and loosen the seven remaining fasteners. Starting from the bottom up, continue to loosen the fasteners and pry out on the bottom of the cover with a large flat-bladed screwdriver, to drain the oil. Once the majority of the oil is drained, remove the fasteners and cover. (Drain plug? Now might be a good time to install one in the cover, if you're so inclined. They make transmission drain plugs that should fit the bill, otherwise, weld in a pipe bung and install a plug. While this won't allow you to drain all of the oil, it'll get most of it out. Ease of service would be improved greatly!) With the Dremel (or suitable marker), mark the orientation of the driveshaft relative to the pinion flange. Spray some penetrating oil on the exposed ends of the driveshaft fasteners, and let set for a few minutes. With the 12-point 12mm wrench, and the dead-blow hammer, break the fasteners loose and remove (you have to rotate the driveshaft to get two fasteners out at a time...). If the shaft hasn't been out for some time (or ever!), you may have to tap the u-joint carrier to get it to break loose from the flange. Place another drain pain under the tailshaft of the trans, remove the driveshaft (depending on the oil level in the trans, you may drain out a pint or so...Some oil will also be present in the yoke.), and install a trans plug to keep from creating a slick. Remove the pinion shaft lock fastener with a 5/16" wrench or socket (it's fairly tight), while holding the differential from turning by inserting a large screwdriver into the ring gear fasteners or holding one fastener with a combination wrench. Once the fastener is out, push or drive the pinion shaft out. Remove the brake drums and push the axles inward, to unseat the C-clips on the axle end; push the clips out with a screwdriver. Once the C-clips are pushed off the axle ends, carefully slide the axles out, taking care not to nick or damage the axle seals. Inspect the axles for bearing damage: the wheel bearing rollers ride directly on the axle (as opposed to in a cup), and can score the axle if improperly lubed or contaminated. If you find axle damage, offset bearings are available to allow you to use the existing axles. set the axles in the wheel so that they are upright; seems a decent way to store the loose parts in an already limited workspace...
With the axles out, attention can now turn to the differential assembly. Mark the caps for proper reassembly; use "L" and/or "R", or any other scheme that you can remember (bottom line: don't mix the caps up! They are machined like engine main caps, so be careful.). Prior to removing the diff assembly, check the backlash [Backlash: The clearance between a pinion tooth and the adjacent ring gear teeth. It is the total movement allowed between contacting teeth.] for reference. Set the dial indicator and magnetic base up so that the tip is perpendicular to a ring gear tooth. Measure and record the backlash: should be in the .008"-.015" range. With a 3/4" socket and break-over bar, loosen the cap fasteners about four or five revolutions, but do not remove yet. The differential assembly may need to be "persuaded" to unseat it from the housing; use a rubber hammer, dead-blow, pry bar, wrench, or a large screwdriver inserted into the ring gear bolts to break it loose (the two units I've done so far have come loose by hand). Once the assembly is loose, remove the caps and set aside. Carefully pull the differential assembly from the housing, while simultaneously grabbing and containing the shims and bearing races on each side. Measure the thickness of the shims and record relative to location, and keep races in order.
Differential disassembly: With the differential on the bench, use a 3/4" impact socket and wrench to remove the ten (10) fasteners that hold the ring gear to the differential case. Once all fasteners are removed, tap the ring gear off of the case with a soft hammer, alternating blows around the circumference. If you are planning to rebuild the traction-lok, remove the S-spring (carefully!) by driving it out (away from you) with a hammer and punch. Rotate the pinion gears (the small ones) around to the openings in the case, and remove (If you have set the axles up vertically in a wheel, it makes an excellent tool for holding one side gear and rotating the differential). The side gears and frictions/steels should all fall out; try and keep them in order, relative to installation side.
Traction-lok rebuild:
A brief traction-lok description: The t-lok, IMHO, is a very simple yet effective method of torque transmission. It uses a combination of frictions and steels; the steels spline to the O.D. of the side gears (the I.D. is splined to accept the axles), and the frictions keyed to the differential case (driven by the ring gear) with tangs. An S-spring is used to provide initial clamping load, then is supplemented by the outward forces created and transmitted by the pinion gears.
rebuild traction lok after gear change , for a couple of reasons: 1. Going to a numerically higher gear ratio, the pinion diameter goes down, and the ring gear thickness goes up. What does this really mean? The S-spring "gap" between the side gears is partially blocked (straight line of sight) by the thicker ring gear (you can still get the spring in, it's just a bit tougher). 2. Without the ring gear, you can support the differential case by the flats (across the clutch cavity) on a block of wood, while driving the S-spring in place. Also, there are two approaches to component order: the factory method, and the alternating method. From the factory, t-lok's are packed in this order: shim, friction, steel, steel, friction, steel, steel, friction, side gear. The alternating pack is as described: shim, friction, steel, friction, steel, friction, steel, friction, side gear. There is some debate on the durability of the alternating method, as you have reduced the number of splined components (thereby increasing shear and contact stresses), while increasing the ability to transmit torque. My contention? I've never seen a rearend go out due to t-lok spline failure; it's usually axle related (OK, at some point the axles become stronger than the steel splines; at which point, I don't know! Maybe somebody ought to "run some numbers"...). Both methods work: satisfy your particular needs and plan accordingly (I prefer and suggest the alternating method, FWIW.). The F5AZ-4947-BA kit will allow you to accomplish the "factory" set-up; for the alternating, you can buy a pack of frictions (see number below), or reuse two (one for each side) of your best existing frictions.
The rebuild: Soak the frictions in gear oil for a minimum of fifteen (15) minutes (while you clean the diff case, gears, and shims) prior to assembly in order to avoid dry working and possible component damage. Be forewarned: the clutches will still pop when first driven (I about had a conniption when I first rolled mine out of the garage after gears and t-lok! The thing popped about a dozen times in turns before settling out. I soaked mine about twenty (20) minutes, but the last set I worked on was soaked for about two hours. Result: only one or two mild pops, even with alternating frictions and a new F-150 S-spring!). With the differential case on one bearing, install the .045" thick shim in the bottom cavity. Apply a few drops of gear oil to the other .045" shim and place in the upper cavity (the oil will hold it in place, as long as the drops are towards the case...). Stack the frictions, steels, and side gear (engaging steels) in the lower cavity per your packing choice, then stack the upper units on the side gear, and install as a unit (make sure tangs locate in case). Install one of the pinion gears in place, and, while holding inward with one thumb, install the opposite side pinion gear 180 degrees apart (I prep the pinion gears first by putting a couple drops of gear oil between the gear and it's steel bearing "shell"). Pick up the whole assembly, and install on the end of an upright axle. Rotate the diff case while holding the pinions inward as hard as possible; if you're lucky, the "assembly" will roll right into place. If the shims are too thick, the pinion gears will not clear the case (acting like a built in gauge...). Change one shim to the next thinnest, and try again. If it fails to go together, change the other shim to the next thinnest: repeat until the gears rotate into position. It's fine to have one shim .005" thicker than the other; just don't end up with a .010" disparity. If the pinion gears line up, and the shaft will go through, you have it correct (It took me about three tries the first time.).
S-spring installation: This is actually the most trying part of the whole procedure! The S-spring, by design, has to be compressed to allow installation. The Ford (Helm) manual directs you to tap it into place with a rubber hammer; maybe one that weighed about 1000 pounds and was frozen rock hard! More people have had difficulty with this one seemingly simple task, and I'm no exception. I fought my first one for about an hour, then finally got it by compressing it in a vise, holding it compressed with a couple of pairs of needle-nose Vise-grips, and driving it into place. Shortly thereafter, Larry Turvy from the Corral offered a great tip: use two, 2" capacity worm-type hose clamps. Larry's original suggestion was to use the clamps to compress the spring, but I still use the vise, then install the clamps, leaving a bit of the end exposed to get the thing started. Place the compressed spring into position, and start driving it into place with a hammer. With all luck, the spring will start in a few blows. Continue driving the spring in, until you stop on one of the "worm" portions of the clamp. Cut this clamp out with aviation or tin snips (Dremel or hacksaw may work), and continue driving, removing the other clamp when required. (Note: I found a 6-8" long piece of 1" x 1-1/2" rectangular tube, used as a "punch", to be very helpful in "persuading" the S-spring into position, especially when using the F-150 unit!). Be careful not to drive the spring all the way through and out the back; sight down the pinhole and roughly center the spring. Set the unit aside for the time being.
Congratulations! You've just completed the Traction-lok rebuild!
