ANOTHER question about the fuel pressure gauge
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Feb 7, 2008
mustangfan1990
505
Lenoir, North Carolina
Feb 7, 2008
  • Feb 7, 2008
Ok I ordered the Isolator for the fuel pressure gauge.....Is it hard to hook up. I am going to hook it up below the radio. Where would be the best place to route the hose and where would be the best place to mount the Isolator..
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 7, 2008
  • Feb 7, 2008
they make clusters to mount gauges under the radio. and our cars have a few removable rubber grommets you can run the line through.
i see you have done an auto to manual swap so you know the grommets im talking about. just make sure you put the line through the grommet o rjust take it out and put ALOT of electrical tape or duct tape around the line to keep it from rubbing through. its fuel deff dont want to chance that.
mustangfan1990
505
Feb 8, 2008
  • Feb 8, 2008
cool, the instructions says that the isolator must be level with the gauge to get an accurate readings. I know the grommets you are talking about but I am not sure if it is level with the gauge!!!
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Feb 8, 2008
  • Feb 8, 2008
just make sure you get it on tight, I had one once on my svo and one day it ran like ass, and turns out the line ruptured and blew gas on my turbo for about 1-2 secs and you should have seen me run from that thing lol, I thought it was gonna burn to the ground...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2008
  • Feb 9, 2008
Try this to prevent that...
For gasoline, use a smaller drill to drill the restrictor orfice. Number drills can be hard to find in sizes 72-76 (.025"-.020"), but that is what you would need.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • Mindseye007
  • Aug 16, 2026
Mindseye007
