Anyone ever replace a roof???
  • Thread starter Thread starter xoxbxfx
  • Start date Start date Dec 31, 2004
xoxbxfx
3,959
Southlake, TX
Dec 31, 2004
  • Dec 31, 2004
Well, a friend has a mustang that needs a new roof. Actually the whole car needs to be replaced but its an effort to save the car from being scrapped and keeping teh hobby alive.
Anyone ever do it before? I have seen it done before (well chop tops) and the biggest thing that I know of is bracing teh inside of the car because you will lose shape if you dont. Anyways, do you think if we did this carefully this is something we could do in a driveway or are we crazy not to hire a pro?
70snake
61
  • Dec 31, 2004
Well, it can be done in the driveway provided you have a welder(and know how to use it) and remember to measure twice, cut once. I've done a 70 Torino Cobra, and the biggest thing I can tell you is:
1.) make sure car is on stands and LEVEL! Use 8 jackstands, and support off the frame rails(4), strut rod mounting points(2), and center of rockers(2).
2.) use 3/8's steel rod and build a cross jig to tie the front of one door jamb to the back of the one opposite it. then where the rods cross weld them together. Do this at both the upper and lower jambs on both sides. At this point it starts to look like a spider web, but it beats not being able to shut your doors later.
3.) try to make your cuts using the factory weld areas, this means some drilling of spot welds(patience!!)
In the long run it may be better to find a shell with a good roof and rockers unless the car is rare or holds sentimental value. This can be done, but it's not for the faint of heart.
krash kendall
1,258
Aldergrove, B.C. Canada
Dec 31, 2004
  • Dec 31, 2004
On the early mustangs the spot weld seams are filled with body lead (a couple inches down on the piller, and a couple inches up from the quarters). Torch out the lead and carefully cut out the spot welds with the appropriate removal bit. Do the same from the inside at the top of the sail panels. Your replacement roof can be sawsalled off at the wrecker as long as you cut below the seams and remove the un-needed portions at home. Then your new roof drops on over the sail panels and attaches at the original seams just like it did at the factory.
I found a good roof for my first stang (someone had cut a sunroof in it) for $300. CDN.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Replace the entire AC charge port
  • from6to8
  • Feb 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 22, 2025
from6to8
R
Brake Master Cylinder replacement steps for 2016 S550?
  • Reybeast
  • Dec 16, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Dec 21, 2024
89ripper
