mmm... why not juice up the stock GT40 heads, port the stock intake and custom cam it???
It would make more power than the stock X heads and be very drivable... and then you can state at car shows stock block/heads/intakes.
Higher intake ports.Never used the X heads but I recall something about them having higher exhuast ports?
I have a set, but they aren't for sale .
Exhaust ports are stock location. But both the intake and exhaust ports are much larger than stock e7s. I had bbk equal headers and the ports on the headers were too small so I went with the JBA cat4ward shorties. Matched a lot better. Intake, you need a large port lower, or port a existing one that you have. I believe the Edelbrock RPM 2 and Trick flow Track Heat\ Street Burner match up nice. I can say for sure the Trick Flow matches pretty close and both Trick flow uppers use the same lower so you can play with your power band. Also you need the M-9439-A50 intake gasket. The FRPP gasket if you want to run the EGR, or a Felpro 1262 intake gasket if you don't plan on running a egr.
I got two tacos for sale. Couldn't finish them. Any takers?In the fox forum, or classifieds?
Kurt
Mill and comp valve job was all I would look at, either head is going to need springs given he's going to cam it anyway... and if he is buying used alum. he's got to be thinking freshen, so moot point regarding guides seals etc.Yes...and it would also cost twice as much and be quite a bit more work than installing a set of stock GT40X heads as well.
I'd say the money side of the coin is going to be too close to call.
Now, IMO, since it's a show car, I would think original heads will award more points than alum., even if they are FoMoCo.
Also take into consideration I am always right... :big smirk:
If someone really wanted to make the car looks stock, they could always give the heads a coat of black or grey paint, then cover them up with some grime.
