Anyone use a spacer before?
  • Thread starter Thread starter PeteyAce
  • Start date Start date Dec 14, 2005
PeteyAce
346
Dec 14, 2005
  • Dec 14, 2005
Im talking about the ones between the upper nad lower intakes, just wondering if there is actually any gain at all or clearance issues
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Dec 14, 2005
  • Dec 14, 2005
I used a 1/2" once before if it added anything i could not tell.. No clearance probs at all..
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Dec 14, 2005
My buddy and i just swapped his motor from his 86 to his 90, and he added a 1" phenolic spacer... he had to say goodbye to his strut tower brace. it was about 3/8" too tall to clear the strut tower brace
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Dec 14, 2005
  • Dec 14, 2005
alot of times you have to use them with the tall valve covers. without it, you couldnt use most roller rockers and valve covers.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Dec 14, 2005
  • Dec 14, 2005
I'd like to give a spacer a try, but there's no way im getting rid of my strut tower brace.
Rick 91GT
Mustang Master
95
99
PA
Dec 14, 2005
  • Dec 14, 2005
It makes a great heat sink, the upper will stay a lot cooler then the lower. It can also add some runner length if you need it....
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 14, 2005
  • Dec 14, 2005
helped alot on the 86 with the GT40 intake.. cooler
L
luckythirteen13
648
Anaheim, CA
Dec 14, 2005
  • Dec 14, 2005
i have a 3/8" spacer. its makes a very noticable effect as far as upper intake temps go. after running the car car the upper manifold is cool enough that i can bare hand it without being burned. i have a sc now so dont really know what the effect is. i have to use it though or my valve covers will hit
slow93
406
  • Dec 14, 2005
im running a 1" spacer on my vortech intake and there is no way it is fitting under a stock hood
2badazzstangs
72
Jersey
Dec 14, 2005
#10
  • Dec 14, 2005
  • #10
1" space here on trick flow track heat heads, I agree with the upper intake being cooler, also I doubt a stock hood will accomodate the extra height, I have a stormin normin hood and it just about hits the upper intake in the back corner. Also the strut tower brace is a no go.
RYC CUKR
1,437
Orlando
Dec 15, 2005
#11
  • Dec 15, 2005
  • #11
I am running a 1" spacer on my trackheat intake. call me lucky but it fits under my stock hood but only by a hair. Since I didn't have it without the spacer I can't tell you if it improved the performance.
M
MatthewP
355
Calgary, Alberta
Dec 15, 2005
#12
  • Dec 15, 2005
  • #12
I ran a 3/8" spacer on an Explorer intake. No hood clearance problems, and the upper definitely stays cooler. The spacer improved ET on a hot lap at the drag strip by 2 to 3 tenths. With the spacer, I could get two back to back runs that were very similar, without it, the second run would always be much slower.
One note though, if you did not block the EGR passages at the heads, or run non-emissions heads, the spacer won't help much because the gasses in the EGR system will heat the upper intake significantly.
-Matthew
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
U
Midrange pods for a pillar?
  • urthecap
  • Sep 17, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 17, 2026
urthecap
U
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
