AOD problem
  • Thread starter Thread starter zugsyn
  • Start date Start date Mar 2, 2011
Z
zugsyn
31
  • Mar 2, 2011
Car dies when put in reverse and low I think its trying to go into 2 gears at once and was told It could be the filter fell off and is floating around in the pan is there truth to this if so when the mud dries up im gonna drop the pan
90 lx convert
Stanger
926
Falling Waters Wv.
Mar 3, 2011
  • Mar 3, 2011
I doubt the filter fell off as its bolted onto the valve body. The only way it would stall the engine is if the converter was locked up somehow. None of the parts in the trans turn in gear while you're sitting still. The converter does all the slipping. I'd check to make sure the idle air solenoid is working. Mike
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Mar 3, 2011
  • Mar 3, 2011
Don't think it's the trans. I think the engine stalls when under load.
Hows it run? What's idle set at?
Z
zugsyn
31
  • Mar 3, 2011
Well you can put it in drive and go down the road but it runs terrible but thank I'll look into the idle and stuff, it only stuff off in reverse and low it will sit and idle just fine in drive so I dont think its the torque converter. but I'll look into that stuff thank you, Ive never been in the transmition but I was on another forrum and they said the filter just kinda snapped on with an O ring.
Z
zugsyn
31
  • Mar 3, 2011
also I dunno if it makes a difference but my Car is Carbed
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Mar 3, 2011
  • Mar 3, 2011
If filter falls off, the pump sucks air and the trans just slips. Been there, done that.
Z
zugsyn
31
  • Mar 3, 2011
well I hope thats it cuz i sure would be an easy fix
90 lx convert
Stanger
926
Falling Waters Wv.
Mar 4, 2011
  • Mar 4, 2011
On all the AOD's I've worked on the filter is bolted on. Mike
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Mar 4, 2011
  • Mar 4, 2011
Yes, it is. But there is a gasket between the filter and valve body. Back when I didn't know anything, I had a shop do my trans flush and they "forgot" the filter gasket. Needless to say the trans slipped like crazy and I couldn't even drive period.
Was trying to tell the op ist NOT the trans...look into the engine
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
