  • SN95 4.6L Mustang Tech
Automatic Shifters - Please Help
  • Thread starter Thread starter Stark77
  • Start date Start date Jun 23, 2008
  • 3
First Prev 3 of 3
speed545
458
Montreal, canada
Jul 13, 2008
#41
  • Jul 13, 2008
  • #41
speed545 said:
Ok, after promising myself not to spend on that car this year, i went through this thread and ordered the B&M kit and the knob
I hate my self
Going under the install today since it is raining here.
I ll sent you your $$$$ for copying CobraRed
speed545
458
Montreal, canada
Jul 13, 2008
#42
  • Jul 13, 2008
  • #42
OK done,
It is time consuming
Looks really cool though. Problems i had:
- need to disconnect parking brake cable from rear caliper to be able to lift park brake handle high enough to remove console
- since i have a 99-04, i have to use that clip and spacer they include in the kit to attach cable to shifter. But there was no bolts included in the kit.
Beside that, everything went smooth.
Havent road test it yet and wife dont see any difference
kalvick
352
Norwalk, CT
Jul 14, 2008
#43
  • Jul 14, 2008
  • #43
I hate everyone in this thread doing this mod! I hate people who made video's on you tube! UGGG!!!! I want to copy this mod too. right down to the shift knob! its sitting in my amazon Cart waiting for me to say buy it.
so let me ask this...
1) how long did it take to install it for you?
2) when you say disconnect the parking brake, that meant you had to go under the car to disconnect it?
3) did you buy new bolts and stuff, or did you recycle parts from the old shifter? if you bought new parts, what model numbers are they? (i want to save time going to Napa or autozone for parts)
4) also i want to join "the Auto can neva' lose club"
speed545
458
Montreal, canada
Jul 14, 2008
#44
  • Jul 14, 2008
  • #44
1) how long did it take to install it for you? Started at 13h00 and finished at 19h00 includind strugling with the console for about 1.5 hours
2) when you say disconnect the parking brake, that meant you had to go under the car to disconnect it?remove the rear wheel and pull out the cable from the caliper using plier. No parts needed.
3) did you buy new bolts and stuff, or did you recycle parts from the old shifter? if you bought new parts, what model numbers are they? (i want to save time going to Napa or autozone for parts) Only things missing was the bolts to fix the 99-04 support to the shifter and i found them in my overstock. Dont need to be specific, i used 2 3/16 bolts and nuts + washer and lock tite.
4) also i want to join "the Auto can neva' lose club" Me too
speed545
458
Montreal, canada
Aug 16, 2008
#45
  • Aug 16, 2008
  • #45
Ok,
bringing it back up for some questions. maybe Cobrared would know.
When installing the new shifter and adjusting the cable, instructions says to pull the slack from beneath the car at the tranny lever and then tighten the bolt.
On my 2001, it s a kind of a slotted part at the end of the cable. This is the only adjustment possible on that cable and when installing the new shifter, i was already at the limit of the slotted part.
I was able to get some more loose from the bracket retaining the cable to the tranny but still, some time, i have to push the shifter to start the car cause the cable still pulling on the lever. So car think it s not in P so it doesnt start.
Only other alternative: remove the entire cable and modify that slotted part to make it longer a little bit. I just need about 1/8''.
Didnt someone ever experienced that???
Thx
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 16, 2008
#46
  • Aug 16, 2008
  • #46
this is my favorite thread ever.
As for the shifting cable - the a common symptom. It was discussed in another B&M thread like last week. He brought it to a shop and they said it was a prob of being just too short but somehow i think they picked up some slack. My shifter does it sometimes too. Either you start the car in neutral - or when you park your car you push it into park with some force so when you start it the gear selector modular is in it's correct position. I'm trying to figure out what i should do to fix the "problem", but i have my attention on my half apart engine right now and don't exactly want to open the shifter area again.
speed545
458
Montreal, canada
Aug 16, 2008
#47
  • Aug 16, 2008
  • #47
Thx.
The cable is in fact too short by about 1/8.
I manage to pick up some play this week and it a a lot better since before that the car would go in between shift some time when manually up shift. Doesnt do it anymore.
I ll just remove the cable and extend the slotted space at the end.
Thx again
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 16, 2008
#48
  • Aug 16, 2008
  • #48
speed545 said:
Thx.
Thx again
The slotted end by the gear modual? Don't do that, drive will be 2nd, park will be reverse ect. It need to be where it was stock which will be where the circle mark will be from it being in that position for so long.
kalvick
352
Norwalk, CT
Aug 16, 2008
#49
  • Aug 16, 2008
  • #49
yea, its defintely too short a cable. the guys that fixed it at the shop, gave me some batter slack to play with, but so far its not perfect. i still run into problems with the car not starting because its not all the way in park. if i give it an extra nudge, it can start in park, and if it wont start in park i can start in neutral.
instead of removing the loop that goes on the transmission bolt (not the loop on the shifter) perhaps dremmel'in the inside of that loop a little bit to shave it.
I am debating doing this. I probabbly will, when i put my car back up on the ramps. But my car is also out of commission with a broken water pump. which my replacement hasnt shipped yet
speed545
458
Montreal, canada
Aug 16, 2008
#50
  • Aug 16, 2008
  • #50
Exactly what i was thinking.
Either that or allowing the nearest support to the tranny to come closer to the lever by also slotting the bolt opening
kalvick
352
Norwalk, CT
Aug 17, 2008
#51
  • Aug 17, 2008
  • #51
Im not sure i am 100% on what you mean. If you do it take a picture so I understand what you are saying.
speed545
458
Montreal, canada
Aug 17, 2008
#52
  • Aug 17, 2008
  • #52
I ll take some pics to show.
Sorry if it s not to clear sometimes, i m french canadian
speed545
458
Montreal, canada
Aug 18, 2008
#53
  • Aug 18, 2008
  • #53
Not easy to take pics under a car witch is 8 inchs from the road
This one showing where the cable attach to the trans lever. The same as before the B&M shifter just go there to adjust the cable after the install
This one showing the last support attaching the cable to the tranny before the trans lever adjustment.
kalvick
352
Norwalk, CT
Aug 18, 2008
#54
  • Aug 18, 2008
  • #54
ok so that was the fix, and it worked? or did you not try it yet, and you are saying that is what you are going to do?
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 19, 2008
#55
  • Aug 19, 2008
  • #55
My bolt position in that first pic is in the middle like stock because when i would adjust it D would no longer be drive it'd be another gear along with the others, but my actuator is a newer model i think; they said the original OEM one was replaced. Still looks the same tho
speed545
458
Montreal, canada
Aug 19, 2008
#56
  • Aug 19, 2008
  • #56
Got it to work fine by just loosening the bolts and retorque after but no i havent done the slotting thing yet. I ll see how it work like that cause so far so good.
  • 3
First Prev 3 of 3
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
T
  • Locked
1990 2.3L automatic - real bad engine sputtering
  • the_steve_randolph
  • Jun 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2024
the_steve_randolph
T
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
