  • 2005 - 2009 Specific Tech
Axle Back
  • Thread starter Thread starter alf1096
  • Start date Start date Aug 25, 2008
A
alf1096
21
  • Aug 25, 2008
Just put on set of frpp stingers and so far I like the sound but I am having a little problem. The passenger side went on great and does not leak. The driver side is my problem I can not get it to stop leaking a little. I have tried rotating the clip and adjusting it several times with no luck. What is the trick or should I just go to the exhaust shop and get it welded on. There is no way the clamp can get any tighter.
J
jasongt06
15
  • Aug 25, 2008
Did you look at the pipe before you put it on? It could be bent slightly and that could be causing the leak. If it is not that you can put some orange sealant on the pipe.
highvolts
20+ Year Stangneter
Sep 1, 2003
436
Ohio
Aug 26, 2008
  • Aug 26, 2008
Orange Sealant?
J
jasongt06
15
  • Aug 28, 2008
It is orange silicone specifically for exhaust leaks.
highvolts
20+ Year Stangneter
Sep 1, 2003
436
Ohio
Aug 28, 2008
  • Aug 28, 2008
Link?
speed1972
891
Denver, CO - Buckley AFB
Aug 28, 2008
  • Aug 28, 2008
make sure you've got it tight enough. it takes quite a bit to get it leak free.
LB
L
Lennyvb
57
Centerport, NY
Aug 29, 2008
  • Aug 29, 2008
highvolts said:
Link?
Google is your friend.
CB Performance - Online Catalog
wusthof
192
BC, Canada
Aug 30, 2008
  • Aug 30, 2008
Unless you're planning to change out your exhaust a lot, I have always welded - clamps are ghetto imo
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Wednesday at 10:17 PM
AlexM556
A
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
