axle swap vs speedometer
  • Thread starter Thread starter jos
  • Start date Start date Nov 18, 2007
J
jos
  • Nov 18, 2007
Hello mustangfans,
I'm rebuilding this 1979 mustang.I changed the 6,75 axle for a 7,5 inch but the ratio went from 3,07 to a 2,47.
Is there a formula to figur out how many teeth the speedometer gear should be.i'm using a C4.If this ratio is not streetusable i will change the pin/gear but so far i have to work with this.Thank you Jos Teunissen (Netherlands)
D
D.Hearne
11,730
south louisiana
Nov 18, 2007
  • Nov 18, 2007
The tooth count on the cable gear will need to be reduced by about two. You can figure one tooth up or down in every .25 difference in the ratio. More teeth going up in ratio, less going down.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Nov 18, 2007
  • Nov 18, 2007
1979 is the first year of the Fox chassis, why not put an 8.8 in ? I'm sure there are plenty of posi 8.8 rear ends in junkyards that will bolt right in. If I remember correctly I think the LX's came with 3.27 ratio gears.
This doesn't solve your spedo gear problem, its just a segustion.
D
D.Hearne
11,730
south louisiana
Nov 18, 2007
  • Nov 18, 2007
He's over in the Netherlands, I guess this stuff isn't as plentiful there as here.
J
jos
  • Nov 23, 2007
Mr Hearne,thank you for workeable info.I drove the car to the inspection.It passed after 10 years of sleep .Unfortunally the rearaxle with 2,47 isnt to drive.Have to change the 7,5 meanwhile i will put back the 6,75 with the 3,07 ratio.
D
D.Hearne
11,730
south louisiana
Nov 23, 2007
  • Nov 23, 2007
(for the first part) on the last part ?
Introducing myself and seeking tips how to repair my 1979 Foxbody chrome strips
  • JosTee
  • May 8, 2019
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2019
JosTee
