  • 1994 - 1995 Specific Tech
Bad Hose
  • Thread starter Thread starter glasersil
  • Start date Start date Nov 4, 2006
G
glasersil
  • Nov 4, 2006
This hose is starting to fall apart. It's attached to the purge canaster/valve. I'm going to the track tomorrow, If this leaks will this affect anything?
http://i101.photobucket.com/albums/m79/skforever1/DSC02228-1.jpgView attachment 427106
BlackVert
5,589
9
98
Bethesda, MD
Nov 4, 2006
  • Nov 4, 2006
it does connect eventually to the intake, but the leak will be minimal. that is the fuel vapor solenoid. the fuel vapor vulcanises the rubber and will make it hard to remove from the solenoid. when you replace it, use a razor blade to cut it off the solenoid nipple. i tried to pull the hose off and i broke the solenoid, and i had to get a new solenoid.
HISSIN50
34
129
Nov 4, 2006
  • Nov 4, 2006
Agreed. I ended up replacing all of that run of line too. Be prepared for the lines at the charcoal cannister (inside the passenger fender, under the antenna base) to look like dog crap too.
Good luck.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
