  • 1994 - 1995 Specific Tech
Bad Starter?
  • Thread starter Thread starter parchisi
  • Start date Start date Jan 20, 2007
parchisi
519
New Mexico
Jan 20, 2007
  • Jan 20, 2007
Car won't start, the starter just grinds. If i'm lucky it'll engage, but I had to push-start it last time. Is this just a bad starter or something else? Also, how hard is it to replace the starter? I wouldnt' know because when I installed it, the engine was out of the car. Thanks peeps.
HISSIN50
34
129
Jan 20, 2007
  • Jan 20, 2007
Sounds like a starter issue to me. Do make sure the starter hasnt fallen halfway out of the car before you go buy a new one. You can have starters bench tested at the parts stores (decent ones anyhow) if desired.
Good luck.
T
Titan2175
23
  • Jan 20, 2007
One thing i would check, even though this might not be part of it, but it was with mine, is check the motor ground and make sure its clean. But i agree the starter may have backed out a little.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jan 21, 2007
  • Jan 21, 2007
Also check the flywheel teeth for excessive wear. But the starter gear is designed to wear before the flywheel, and this is the likely case.
The starter is 3 bolts i believe. It's not easy to get to them. IIRC I use about 3 feet of extensions and found a almost straight shot to the bolts from in front of the lower control arm (which was a life saver). Wobbles and u-joints are a necessity. A stubby ratcheting wrench would also help.
Don't forget to disconnect the battery unless you want your wrench welded to the starter posts!!!!
Scott
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
