  • 1994 - 1995 Specific Tech
Barometric pressure sensor?
  • Thread starter Thread starter 88 Fox GT
  • Start date Start date Aug 23, 2004
88 Fox GT
1,674
Iowa
Aug 23, 2004
  • Aug 23, 2004
Where can it be found on the 94-95? I can't seem to find one.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 23, 2004
  • Aug 23, 2004
Yes, there is a reason you cannot find it .
Dave
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 23, 2004
  • Aug 23, 2004
I don't know if we even have one. I know where it is on a Fox, but not ours!
Scott
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Aug 23, 2004
  • Aug 23, 2004
I think the mass air sensor does that job.
88 Fox GT
1,674
Iowa
Aug 24, 2004
  • Aug 24, 2004
That's what I was thinking also. I know the Foxes had them mounted on the firewall, but can't find one on this 94. I think the mass air flow sensor can measure air density also so it probably does not have one.
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
Aug 24, 2004
  • Aug 24, 2004
We don't have one.
Silver85TC
130
  • Aug 25, 2004
The comp does need to know what the baro pressure is.....so can any one confirm how it determines the baro pressure?
The MAF sensor is the only way I can think of.
95strokerPSU
986
Sacramento from Philly
Aug 25, 2004
  • Aug 25, 2004
94-95 don't have a BAP sensor. I did the PIH switch and in the process pulled up a wiring diagram from All Data to compare the 93 to a 95 computer. On the 93, pin 47 goes to the BAP and on the 95 it goes to the Mass Air. So I would conclude that 94-95's are controlled through the mass air.
Silver85TC
130
  • Aug 25, 2004
Cool. That's what I figured. I guess that's also why a dirty/faulty Mass Air meter seems to cause more havoc on a 94/95 vs a Fox.
Has anyone come across a book or a website that explains the differences between the Fox computer's and the 94/95 computer's?
Thanks
95strokerPSU
986
Aug 25, 2004
#10
  • Aug 25, 2004
  • #10
Thanks
What do you want to know about it? If you want to know what pins control function (i.e: Pin 47 controls Mass Air), I have print outs from All Data that show a 1993 5.0 wiring diagram and also 1995 5.0 wiring diagram. If that's what you want I could maybe fax them to you.
Silver85TC
130
#11
  • Aug 27, 2004
  • #11
I'm trying to eliminate a very minor random tremor at idle. It shows up as the RPM's drop below 1000. Most people don't notice it until I point it out to them. The idle RPM doesn't change at all on the tach (700 RPM), but it's just enough to cause the engine to shake a slight amount. (I know, I'm being very anal!) It's almost like I've got a bit of a cam in the car.
The minor stumble is a little more obvious when the car is cold, and almost disappears when the car is warm. The car runs as smooth as silk above 1000 RPM and pulls very hard all the way up to redline.
I've done a complete tuneup, checked codes, cleaned MAF sensor, EGR valve and IAB valve, new IAT/ECT/O2 sensors, new balancer, new motormounts and haven't been able to find any vacuum leaks. Except for a 190 lph fuel pump and a cat back, my car is pretty much stock.
Anyways, that's why I was asking about the BAP sensor and the differences between the 94/95 PCM and the Fox PCM. I've heard a bad BAP sensor can cause minor problems, but that's obviously not it since our car's don't have one.
I've also heard that this was a very common problem with the 94/95 GT's and Ford even issued a service bulletin stating that minor motor shake at idle was "acceptable"?!?! WTF?
I've owned 3 other Fox 5.0 Mustangs, and they all had an extremely smooth idle.
Anyone have any more information or ideas on this?
Just ignore this post if you think I'm being to anal!!!
MLC Stang
210
Atlanta, GA
Aug 27, 2004
#12
  • Aug 27, 2004
  • #12
Guys,
A BAP (Barometric Absolute Pressure) sensor is required on cars that use the old Speed Density method of determining engine load. This is an idirect method involing calculations from various sensor readings including the BAP.
Our cars use the MAF (Mass Air Flow) sensor to directly measure engine load by determining the mass of the incoming air charge. No calculations or BAP needed. The MAF does it all.
My old '88 Lincoln Mark VII LSC had one on it because it used Speed Density, not a MAF.
baglock1
The Bartender
6,612
Space Coast, FL
Aug 27, 2004
#13
  • Aug 27, 2004
  • #13
Mines located in the center console... on my GPS.
donjohn
1,757
Irvine - Southern California
Aug 27, 2004
#14
  • Aug 27, 2004
  • #14
Silver85TC
130
#15
  • Aug 27, 2004
  • #15
That's not quite correct. All of the MAF Fox Mustang's used a BAP sensor. The speed density 5.0's used a MAP (Manifold Absolute Pressure) sensor. The sensor itself looks the same for MAF and speed density. The only difference was the MAP sensor was connected by a vacuum line to the intake manifold and the BAP sensor was open to the atmosphere.
94/95 was the first year where a standalone BAP sensor was not used on a MAF 5.0 mustang.
That would be why the 94/95 5.0 Mustang is so sensitive to MAF meter problems, compared to an earlier Fox 5.0 Mustang.
Hope that clears things up.
Cheers
Silver85TC
130
#16
  • Aug 28, 2004
  • #16
I stand corrected!
I've been talking with a guy at The Corral who says there is an actual BAP sensor located inside the case of the PCM on 94/95's. The MAF meter is not used in this calcualtion. I'll post more when I find out where he gets his info from.
I must admit I'm becoming very confused now!
Cheers
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
Electrical Help me find a missing connection
  • Xavierg208
  • Feb 15, 2026
Fox 5.0 Mustang Tech Feb 17, 2026
Mcmahst
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
Paint and Body Rust what to do now
  • 97sn95
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
A
Injector question
  • arrickburke
  • Sep 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 19, 2026
arrickburke
A
