battery blew up need advice
  • Thread starter Thread starter spade33
  • Start date Start date Dec 19, 2006
spade33
198
Tempe, Arizona
Dec 19, 2006
  • Dec 19, 2006
so i dont know if many of u remember my last post about the battery draining but it just took a step worse. so the battery did this once before and i dont know why i didnt mention it but i forgot the battery started to smell of sulfer and then you could hear it almost boiling, well then that one died completly. so today it started to smell with my new battery and i thought nothing of it becuase i figured i would fix it later. well after i got to my house my car had been sitting for a while then i hear a very loud BANG i run outside to find that the caps on the battery had poped off and needless to say taht ones done for. My question is what would be causing the batteries to do this why do they keep over heating or exploding? oh and also a little update on my car the other day my hood flew up while i was driving luckly i was going slow so it only ruined the hinges and the hood is salvagable but anyways if anyone can tell me what would be causing my battery to smell and sizzle it would be great thank you guys
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 19, 2006
  • Dec 19, 2006
Check your voltage regulator. Sounds like it's overcharging.
Voltage with engine revved to 2500rpm should not exceede 15V
R
RedGTvert
3,129
Wellington, FL
Dec 19, 2006
  • Dec 19, 2006
Definately sounds like a voltage issue, overcharging. Bubbling is a sign of overcharging.
E
Eyeless_Seven
57
  • Dec 20, 2006
If its draining and blowing up , I would look for a postive wire that's grounding out on the body. or in the vicinity of the exhaust\motor mounts.
degins
361
Texas
Dec 20, 2006
  • Dec 20, 2006
The Sulpher smell is H2S, the explosion is from hydrogen build up. Both are from charging/overcharging. The battery acid will eat right through sheet metal and make a mess of your engine compartment components. Clean up any spilled or splattered battery acid with 5% sodium bicabonate solution (1/2 cup baking soda in a gallon of water). Remove the battery first to prevent electrocution. Be carefull not to get the acid on you, concentrated sulphuric acid is very dangerous.
19stang66
689
  • Dec 21, 2006
hooray for chemistry
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Yesterday at 9:08 AM
SchwarzStock
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
98 GT Alternator will not charge battery.
  • johnsadler05
  • Jul 13, 2024
SN95 4.6L Mustang Tech Aug 10, 2024
johnsadler05
J
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
