Battery Cable Replacement
  • Thread starter Thread starter KFRG
  • Start date Start date Apr 25, 2009
K
KFRG
41
  • Apr 25, 2009
Hey guys,
Planning on doing this, anything I need to know? I read somewhere that one should be replaced before the other? My Haynes manual does not even touch this.
Thanks.
HISSIN50
34
129
Apr 25, 2009
  • Apr 25, 2009
Maybe you remember that the negative terminal is the first and last to be disconnected and connected, respectively. This is simply to help minimize the chance of causing a short while wrenching on the positive terminal.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 25, 2009
  • Apr 25, 2009
OEM Ford ground cable. Note the pigtail and the computer ground connections.
Do not forget to ground them if you replace the negative battery cable.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Drivetrain TV cable replacement--aftermarket or search other models?
  • chazmanaz
  • Dec 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
