Battery Disconect Switch???????
  • Thread starter Thread starter 1 low 5.0
  • Start date Start date Jun 11, 2005
1 low 5.0
Lockport, Illinois
Jun 11, 2005
  • Jun 11, 2005
I need some advice on connecting a battery disconect switch. I have relocated my battery on my 89 Mustang to the trunk. I understand I need to connect a remote battery cut-off switch. How do I wire the damn thing to shut off the car when I put the switch in the "off" position. I think somehow I have to tie into the alternator power? Can anyone help??????
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jun 11, 2005
  • Jun 11, 2005
You want to run the cut off switch to ground. Useing the power side of the battery, if the alternator is still turning, aka the car still on, you won't beable to cut the power. NRHA requires the cut off switch to actually cut the ground. Good luck, bro,.
loud 95
562
Milwaukie, OR
Jun 11, 2005
  • Jun 11, 2005
The switch has to be attached inline somewhere to the positive battery cable. The popular place on foxs seems to be behind the license plate. This way, it is not visible during street driving. At the track, just hinge your license plate so it folds down to expose the switch. I have a '95GT with trunk-mounted battery. I have a tailor box, which holds the optima and flaming river switch inside it. My "switch" is the long-rod kit from flaming river. My rod goes from the lever inside the tailor box through the trim/sheet metal of the trunk and out the bumper. NHRA stipulates that is must be a push off style switch and must be clearly labeled as such.
04sleeper
2,674
14
89
Dallas, TX
Jun 11, 2005
  • Jun 11, 2005
You could always wire the switch to a relay that would cut off the excitor wire on the alternator when the switch is cut off. This could be done with either the positive or negative side of the battery.
M
MATREDGT
59
Shelby Twp., Michigan
Jun 11, 2005
  • Jun 11, 2005
I just got done doing this on my car and this is how i hooked it up. I ran a wire from the positive side of the battery and the charging wire from the alternator to one terminal on the switch. On the other side of the switch I hooked up the wire that runs up to the starter solenoid. The car shuts off immediately once the switch is turned to the off position. Hope this helps and good luck with yours.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
