Well I recently started to notice that the AMP light in my dash was staying on after i turned off my car and removed the key. It would turn off when i started the car or when i was in the RUN position. I have removed various items such as Stereo AMPS and aftermarket fog lights and the what not. To see if anything was shorting the power. and still nothing.
I do however have a question for a question ... Would a faulty ignition cylinder or ignition switch cause my Blinkers to not work, my Fan for the vents to not turn on, or even discharge my battery by keeping something on? i do notice that something turns on like maybe my fuel pump when i reconnect my battery. When the key is OFF. So would that be running All the time. Would i need to change my ignition cylinder or my ignition switch or is it the SAME thing?
THanks
Daniel
THanks
Daniel
