  • 1994 - 1995 Specific Tech
Battery Relocation Clarification
  • Thread starter Thread starter HGFireHazard
  • Start date Start date Jan 12, 2008
HGFireHazard
460
Michigan
Jan 12, 2008
  • Jan 12, 2008
When I pull the car back out in a couple of months I need to put in a new alternator. I've decided on the 130 amp PA Performance one, but they want me to make some wires larger... which is just a great excuse for me to put the battery in the trunk.
I've read enough stuff about wires and crap to make my head spin, so I want to do this right.
I'm looking at a Taylor box and a Moroso cut off switch.
My understanding is that 1/0 is a good and safe choice to go from the battery to the switch, and then from the switch (unfused) to the starter. I would also use 1/0 to ground the battery to the popular quad shock bracket.
From here things get a bit fuzzier for me.
To make the switch work as it should I need to run the alternator wire directly to the + terminal on the battery, correct? I don't believe I need to use 1/0 for this, is 4 AWG sufficient, or should I use 2 AWG? What size in-line fuse should I use here, if any?
I would then connect the starter to the fuse box. I've assumed that 4 AWG is sufficient for this as well, is that correct?
Beyond this, I would run one additional ground from the engine to the chassis. Now, some people have said to run this from the - battery terminal all the way up into the engine bay... but to me that's a heck of a lot of 1/0 on the car. I would rather just do the first if the second isn't necessary.
Finally, I've read a bit about the ground for the ECU and the need to use a 10 AWG wire to ensure the ECU runs the same as before. Is this true? If so, would you run the wire from the current ground back to the - on the battery?
I know it's a lot of questions but I think this thread can be helpful to anyone looking for more definitive answers to these questions.
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Apr 4, 2008
  • Apr 4, 2008
How did you end up doing this, cause I just ordered a relocation kit as well...
HGFireHazard
460
Michigan
Apr 4, 2008
  • Apr 4, 2008
I decided to wait because I couldn't get clear answers on the questions.
I instead opted for an ignition beef up. When I get a new battery I will do these then. Sorry I can't help further.
EDIT: If it helps at all, when I decide to do this I'm going to get an Optima battery with a nice looking billet or something hold down and not a box. I'm going to get the cut-off switch and put it behind the license plate as others have done.
This is how I had it in my head:
+ Battery to Toggle Switch (1 Battery Terminal, 1 1/0 Connector)
+ Toggle Switch to Starter (2 1/0 Connectors)
+ Starter to Distribution Box (2 4 AWG Connectors)
+ Alternator to Battery (2 4 AWG Connectors) (unless get battery terminals that accept wire)
+ Alternator In-Line Fuse (2 4 AWG Connectors) (unless get ANL fuse holder that accepts wire)
- Battery to Quad Shock Mount (1 Battery Terminal, 1 1/0 Connector)
- Quad Shock to Engine Ground (2 4 AWG Connectors)
- Engine Ground to Chassis (2 4 AWG Connectors)
The only change I might make would be to move the alternator wiring up to 2 gauge, and be sure to include a fusible link in the wiring from the alternator to the battery.
Bosko5.0
1,067
longwood, FL
Apr 6, 2008
  • Apr 6, 2008
take a look at this,also check the links.
http://forums.corral.net/forums/showthread.php?t=648005&highlight=battery+cable+relocation
95cbr331
79
Port Orchard, WA
Apr 6, 2008
  • Apr 6, 2008
Im in the process of doing this now... and ive found the link mentioned above helpful
Bosko5.0
http://forums.corral.net/forums/show...ble+relocation
as well as this
i have 1/0 gauge for my + and -, both running to the front, and 2 ga running to the front that will be going to the alternator. In the middle of doing anything and everyhting to the car so i havent done to much more besides mount my switch in the trunklid which looks awesome and ran all the wires
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
