Best flywheel?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Nov 23, 2006
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 23, 2006
  • Nov 23, 2006
Whats the best flywheel for drag/street application? Alum or steel? It's not a dailyu driver but i do drive it on nice days on the street. peace
john
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Nov 23, 2006
  • Nov 23, 2006
If you have tires that can take the shock of a stick trans drag launch, I would say steel. Steel will be a little easier to drive on the street than aluminum depending on gear ratio.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 23, 2006
  • Nov 23, 2006
If you're gonna spend the money on a good SFI flywheel, aluminum is the choice. Mine drives fine on the street
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 23, 2006
  • Nov 23, 2006
I run slicks 26/10's. Tremac tko 28 spline mosher axles and 4:10's going to go with a spec stage 2 or 3 clutch, i will also have added clutches to the rearend. peace
john
thumper460
3,022
Orange Park , Fl
Nov 23, 2006
  • Nov 23, 2006
The steel is a "flywheel" and the weight acts like extra torque!! It is the best all the way around!! the alum is light and you will loose some low end torque, the engine will rev faster ( no heavy flywheel to get moving) but the launching ability with tires at the track sux!!
Just me...............................
Thumper
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 23, 2006
  • Nov 23, 2006
The aluminium would be the way to go for a drag racing only car. It is a lighter rotating mass for the engine to spin thus you are going to lose less power. That being said it may take a little time to get used to the lighter flywheel as stalling can be an issue from dead starts when you are on the street. I bought a steel SFI approved flywheel because i was doing more street duty then track. Spec makes good flywheels i hear and i like my centerforce flywheel i have.
W
wicked84gt350
113
West palm bech florida
Nov 23, 2006
  • Nov 23, 2006
I allways thought and have allways heard that a aluminium flywheel was better for road racing and oval type stuff because you never really come to dead stop or need to launch you just need to turn the rpms faster. And I have have allways though that a steel flywheel was better for drag racing because it keeps up the kenetic energy there for causing the car to launch harder. So you really need to decide on what you are doing drag or circle. And what you really want to accomplish. Personally I like a steel flywheel because its easier for daily driving and laying some bad ass patches.
65ShelbyClone
4,675
38
119
Nov 23, 2006
  • Nov 23, 2006
Aluminum is better for road racing because the engine responds faster. For roundy-round, it doesn't really matter if the engine rpm doesn't fluctuate much. Most circle track engines seem to use 7" clutches and light flyhweels, though. For drag racing, it depends on how hard of a launch you can make stick. I saw an article in MM&FF where a steel wheel was replaced with an aluminum flywheel to help soften the launch on a dedicated drag car.
Just FYI, a heavy flywheel will not cause an engine to make less power. It will only show up as a loss on an acceration/inertia dyno. A steady-state brake dyno will show the same power between aluminum and steel or the difference will at least be smaller than the dyno's margin of error.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 23, 2006
  • Nov 23, 2006
So you are saying if the rotating mass is heavier you woun't see less power at the rear wheel? Seems wierd since larger wheels cause lose of rwhp larger brakes do aswell. All rotating mass. Its drive line loss. True you don't lose hp the engine can make but you do soak it up so it doesn't get to the rear wheel. Actually re reading your post shelby i think we almost agree.
65ShelbyClone
4,675
38
119
Nov 23, 2006
#10
  • Nov 23, 2006
  • #10
Like I said, the steel flywheel will show the loss only when the engine is accelerating. A car might be a hair slower in the quarter mile, but the top speed will be the same.....indicating that there is no difference in power getting to the ground with a heavy wheel. Driveline and parasitic losses are different because that is where horsepower is actually lost to heat from friction.
aleborjas
610
#11
  • Nov 24, 2006
  • #11
hey hello people how can you say aluminum is better for drag racing? when you have sticky tires you need wheight to keep the inertia on the crank and more if is a heavy car, the weight helps you keep the torque and to keep the engine in high RPM's during shifting and does not let the engine dye when you take off the foot from the pedal...
Aluminum is for road racing!
aleborjas
610
#12
  • Nov 24, 2006
  • #12
The wheels are not going keep the inertia on the crank or yes? i dont think so! you want to keep the engine up high during shiftings.
teel me something why drag racing automatic car use heavyer flywheels?
65ShelbyClone
4,675
38
119
Nov 24, 2006
#13
  • Nov 24, 2006
  • #13
Nobody said aluminum was better for drag racing, but I'm not going to argue over which is best for whatever application. I purposely avoided doing just that.
N
niklid05
140
Kutztown PA 19530
Nov 24, 2006
#14
  • Nov 24, 2006
  • #14
How bad will an aluminum flywheel hurt a 12 second notch on the strip? (not a heavy car or hardcore 9.XX car)
65ShelbyClone
4,675
38
119
Nov 24, 2006
#15
  • Nov 24, 2006
  • #15
It will make more difference at the lights. If you can mantain your 60' time, there probably won't be much difference.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 24, 2006
#16
  • Nov 24, 2006
  • #16
i see your point sir. I guess i was under the wrong impression. So drag racers want to lighten everything on there cars but the flywheel. Or at least alocate the wieght to the right spots on the car.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Flywheel
  • Barry
  • Mar 10, 2026
1974 - 1978 Mustang II Talk & Tech Mar 11, 2026
Barry
Which Lakewood Front Struts Would Work the Best?
  • 93gtmustang
  • Nov 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2025
Ethereal_Zer0
E
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
