black and grey connectors on driver side harness
  • Thread starter Thread starter tnardo
  • Start date Start date Aug 11, 2004
tnardo
664
Norwalk, Ohio
Aug 11, 2004
  • Aug 11, 2004
Im in the process of doing a 4cyl - 5.0 carb swap. I know it's not really necessary to know what all the wires mean but i would really like to know.
i broke some wires when i was relocating the harness. what i need is a pinout for the black and grey connectors....what is each wire for.... i know fletch's web page list only like 4 of those wires.. i believe he got the info from a chiltons... can some one please provide me with some of thise information
also theres a few wires that i cut that dont need to go anywhere. what do u guys think is the best way to seal them off.. i was thinking about dipping them in some of that liquid elctrical tape.
tnardo
664
Norwalk, Ohio
Aug 11, 2004
  • Aug 11, 2004
look what i found
Based on 1988 MUSTANG wiring schematics:
When you look at the primary harness that goes from the engine to the computer, you should have 3 connectors that tie back into the main wiring harness. One connector is next to the computer and the other two are at the drivers side firewall next to the master cylinder. The one by the computer is connector #135 the two others are #201 and #403.
WIRES
IN BOLD ARE REQUIRED CONNECTIONS
# 135 (The one by the computer) should have 5 active pins with a total pin count of 8. They are as follows
wire # Color Function
657 Tan Cluster EEC Malfunction Light(2.3 ONLY)
687 Gray/yellow ignition switch "RUN" Power To Oxygen Sensors
97 Tan/lt green Computer Control fuel pump relay (computer grounds this to turn relay on)
359 black/white Transmission neutral sense switch
361 red Power from EEC relay to fuel pump relay(fuel pump coil power)
#403 should again have 5 active pins with a total pin count of 8
258 white/pink low oil level sensor
348 lt green/pink thermostatic switch to AC
32 red/lt blue Ignition start Power to Distributor module
11 dk grn/yellow Tachometer gage feed from - coil connection
16 red/ lt green Ignition switch "RUN" To EEC Relay(turn on EEC in run position)
#201 should have 6 active pins with a total count of 8
33 white/pink Starter relay energized(thru clutch T to #32)
39 red/white Temperature gage
31 white/red Oil pressure gage
199 lt blue/yellow Transmission Neutral Sensor switch Return
150 dk grn/white Trans speed sensor
563 orange/yellow Trans speed sensor
787 pink/black fuel pump relay status(mass flow ONLY)
D
dromeda
146
  • Aug 11, 2004
Check this site for loads of wiring pics (in color too):
http://www.veryuseful.com/mustang/tech/engine/
Specifically:
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
