Blown Head Gasket.
  • Thread starter Thread starter Edster
  • Start date Start date Jul 16, 2012
1 of 2 Next Last
Edster
500
League City, Texas
Jul 16, 2012
  • Jul 16, 2012
I'm gonna replace my head gaskets but my budget is a little tight, so what would be best for the money. I've seen them as low a fifteen bucks each to forty and much more. Unfortunenatly there's not detail on the different gaskets.
Sent from my SGH-T959V using Tapatalk 2
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jul 16, 2012
  • Jul 16, 2012
Fel Pro 9333-PT-1 will do the job well. About $20 each and available almost anywhere.
http://shop.advanceautoparts.com/bu...-gasket-by-felpro-part-9333-pt-1-gaskets.html
horse sence
8,360
233
Wile Coyote's stunt double
Jul 16, 2012
  • Jul 16, 2012
Fel pro is about the best for the buck wouldnt go cheep here
head gsakets are not fun to change in the car
T
Tropic03GT
Jul 16, 2012
  • Jul 16, 2012
+1 for felpro all I use at work I pull heads all the time bc ppl want to play mechanic and use some half ass head gasket that ends up blowing.
Edster
500
League City, Texas
Jul 16, 2012
  • Jul 16, 2012
Yeah, I've always been a Fel-Pro fan. I saw some Fel-Pro gaskets around $15 then $20, $40, and $100. I'm just womderin' about the differenc 'tween the cheaper ones and how they would hold up over time. I don't remember what I put on back twentuy years ago when I built the engine. I'm runnin over 10:1 compression yet I hope that I don't have to fork out $200 for some gaskets, but I will if I absolutely must.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 17, 2012
  • Jul 17, 2012
I used the "cheap" Fel Pro for years till i switched to the Fel Pro MLS (for the turbo)
67rcks
373
Jul 17, 2012
  • Jul 17, 2012
pick any non-MLS felpro
cheaper felpro 8240 (I guess) than 9333 is OK too, IMO even better for non-machined blocks/heads because it has milder steel rings (rest is identical)
Edster
500
League City, Texas
Jul 17, 2012
  • Jul 17, 2012
I really didn't thin it would make much of a difference, but I thought I'd ask just because technologys has improved over the years.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 17, 2012
  • Jul 17, 2012
If you are going to reuse your head bolts make sure to put them back in the exact hole they came out of.
horseballz
824
Las Vegas, NV
Jul 17, 2012
#10
  • Jul 17, 2012
  • #10
Re-use of head bolts should be avoided if at all possible, due to stretching at specified torque. If you have to do it, do as Rusty said and make sure all threads are clean and re-use only for the lowest of performance (compression) applications. As with any torque dependent fastener, make sure to lubricate the threads and underside of the bolt heads to achieve maximum clamping force for the given torque. With a small block Ford, on the lower head bolts that need thread sealant, the sealant (while still wet) adequately doubles as the lube. "A lubricated threaded fastener will provide up to 17 times more clamping force than a dry threaded fastener!"
My $.02,
Gene
67rcks
373
Jul 18, 2012
#11
  • Jul 18, 2012
  • #11
not all small blocks have stretching bolts. e.g. older 302s have regular bolts (reusable in any hole). if you have strechning bolts do not reuse them.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 18, 2012
#12
  • Jul 18, 2012
  • #12
67rcks you shouldn't reuse them in different holes. ARP put out a white paper on this after an extensive study. I don't have a link to it but I'm sure I can scare it up.
rbohm
6,698
550
204
tucson,az
Jul 18, 2012
#13
  • Jul 18, 2012
  • #13
regarding which gasket to use, in my opinion felpros are the best, or at least very near the top.
in regards to the head bolts, stock 302 head bolts dont stretch much, and are not torque to yield bolts, however chances are that they are original equipment and are tired. do yourself a big favor a pony up the few extra bucks and get a set of ARP head bolts for your ride. and dont forget the ARP lube that goes with the bolts.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 18, 2012
#14
  • Jul 18, 2012
  • #14
Or go with studs !
67rcks
373
Jul 19, 2012
#15
  • Jul 19, 2012
  • #15
horseball (maybe others) which small blocks do need sealant on lower head bolts?
I saw 302 and the threaded hole did not protrude to cooling system, why would you then seal the threads?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 19, 2012
#16
  • Jul 19, 2012
  • #16
It can't hurt to put it in there right ? Better safe then sorry....
rbohm
6,698
550
204
tucson,az
Jul 19, 2012
#17
  • Jul 19, 2012
  • #17
to be honest i have never put sealant on any head bolts, even a small block chevy where i knew the heads bolt holes went into the cooling jacket, and i have never had a leak. the key is to keep the bolt holes and bolts clean, and torque them properly.
horse sence
8,360
233
Jul 19, 2012
#18
  • Jul 19, 2012
  • #18
it is also a good idea to run a tap down the bolt holes to clean out any rust or carbon build up ,you can tape off the cylinders to keep crud out when chasing the threads
dont break off the tap been there done that ,wont do it again
J
j69302
325
Jul 19, 2012
#19
  • Jul 19, 2012
  • #19
Agreed. I never used sealant on any either. The 69 ford shop manual, and my Haynes manual do not state any sealant either, just oil.
I did however use new arp bolts any time I pulled them off, and the fel pro gaskets with the pre-flattened copper ring around the cylinder opening.
rbohm
6,698
550
204
tucson,az
Jul 20, 2012
#20
  • Jul 20, 2012
  • #20
the copper ring works nice, but i tend to prefer the steel fire ring instead. just a preference though.
1 of 2 Next Last
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
