bump steer
  • Thread starter Thread starter wfridolfson
  • Start date Start date Mar 16, 2013
wfridolfson
  • Mar 16, 2013
hello everyone, new to the site, i have a 69 fastback and the steering is driving me crazy, want to switch to either manual or power rack, question is does the manual rack turn easier than a mustang with original manual steering
horse sence
8,407
233
Wile Coyote's stunt double
Mar 16, 2013
  • Mar 16, 2013
i havn't tried one yet, but i am going with the borgeson power steer box in my 69
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Mar 17, 2013
  • Mar 17, 2013
I'm considering the same route for my '65.
M
MitchGT
204
Mar 17, 2013
  • Mar 17, 2013
I put in a total control manual rack, and it's a little tough in parking lot situations, but on the open road it's fine. I only have 225 size front tires, and a small block, so that makes it easier. I haven't driven an original manual steer in a long time, so I can't say exactly how much it differs...
Hack
1,945
Minneapolis
Mar 18, 2013
  • Mar 18, 2013
I replaced the manual box in my '70 with a rebuilt unit and it steered much, much easier. I've also noticed a huge difference if I let my front tires get a little low vs. recommended pressure.
If you have an old, worn out manual steering box - a new box built by anyone will be a huge improvement. If the manual box in your car is relatively new probably only the power options will make a big difference.
rbohm
6,698
550
204
tucson,az
Mar 18, 2013
  • Mar 18, 2013
when you say driving you crazy, how do you mean? are you getting bump steer? or does the car wander and you have a lot of play in your steering wheel? if you have a lot of play, then there are a few things that can be causing it, a bad steering gear, a bad suspension alignment, or a a bad front suspension, or a combination of all three.
swapping to a rack and pinion steering wont necessarily help the situation, and has other issues you have to deal with as well. personally i would start by checking the condition of the front suspension, then the suspension alignment, then the condition of the steering gear. i second the option of swapping to a borgeson power steering gear to your stang.
horseballz
824
Las Vegas, NV
Mar 19, 2013
  • Mar 19, 2013
Borgeson box = Best upgrade I've done to date!
callys
76
  • Mar 19, 2013
Are you running the borgeson box with the factory ford pump or with their pump? It seems like by time you get their pump the setup is 2/3 the cost of rack and pinion
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
