  • SN95 4.6L Mustang Tech
Buying Longtubes, What Else???
  • Thread starter Thread starter JOHNS01GT
  • Start date Start date Jun 14, 2005
J
JOHNS01GT
209
Vermont
Jun 14, 2005
  • Jun 14, 2005
I'm buying the slp longtubes w/matching shorty x, now do I need anything else? Like O2 sensors, extenders, MIL eliminaters??? I have a tune not a chip, but I will be getting dynoed after the install.
J
JOHNS01GT
209
Vermont
Jun 14, 2005
  • Jun 14, 2005
Anyone with long tubes know?
SilverBullet00
1,150
Wichita, KS
Jun 14, 2005
  • Jun 14, 2005
You will need O2 extensions for the front O2 sensors. If you have a tuner you dont need to get the mil eliminators because you can disable your rear sensors with the tuner. Another thing I would seriously look at is the best possible header gaskets you can find. I know I used the $hit BBK ones that came with my headers and I REALLY regret it. Other then that, have fun with the install, I know I did
J
JOHNS01GT
209
Vermont
Jun 14, 2005
  • Jun 14, 2005
Thanks, can't wait!
MineralG2k2GT
451
Lowell, MA
Jun 15, 2005
  • Jun 15, 2005
You will need the 02 extenders, new gaskets from ford and most likely the MIL's. And also you should get some new header bolts as the studs will not all fit back in becuase of the placement of the runners on the heads
when i did my install the back two cylinders on both sides did not give enough clearance for the header studs to go back in so i had to use some bolts i bought from home depot
one more thing to keep in mind is with the install of long tubes, you will lose the ability to change your clutch (unless you buy hooker headers). I am not sure how many miles are on your car, but if you were like me (with 40K) it was about time for a clutch change so i just did that at the same time.
just a thought
J
JohnyD05
417
Massachusetts
Jun 15, 2005
  • Jun 15, 2005
Tell me how much power you gain on the dyno i am thinking of the same mods. Are you going with cats or not?
posm6s
144
Eddyville, KY
Jun 15, 2005
  • Jun 15, 2005
You will also need lots of beer.
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
