C4 trans shifter shaft
  • Thread starter Thread starter Rascal M
  • Start date Start date Aug 1, 2006
R
Rascal M
  • Aug 1, 2006
I hope someone can help me. I have a 66 Mustang and I had to replace the C4 trans. I bought a rebuilt one from Auto Zone and the shifter shaft in the side of the transmission is for a column shifter. Can I take out the shaft and rotate it up to work with a floor shifter or do I have to buy a new shaft.
Thanks for the help.
brianj5600
1,964
Middle TN
Aug 1, 2006
  • Aug 1, 2006
You can change them, but not flip them. I guess you already turned in your core. To swap them is not hard. You might try a trans shop and see if they will trade them out.
thehueypilot
1,084
Medina,Tennessee
Aug 1, 2006
  • Aug 1, 2006
I just put the C4 that came out of my 68 into my 93 and flipped the lever from the bottom to the top and it works just fine.
brianj5600
1,964
Middle TN
Aug 1, 2006
  • Aug 1, 2006
The one I had was a different length arm. The column shift arm was longer so it needed more travel than my shifter had.
R
Rascal M
  • Aug 2, 2006
Thanks for the info.
I think I will try and flip it over to see if it will work. But I was thinking I would have to replace it.
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
