I'm in the process of putting together a parts list for a planned 393w stroker build. Here's the pertinent info:
393w
9.5 CR
AFR 185/61cc
Weiand Stealth intake
750cfm vacuum secondary
built C6
~2500RPM TC
1-5/8" Hooker Comp longtubes
2-1/2" Magnaflow X-pipes
9" Detroit Truetrac rear
25.8" tires
subframe connectors (welded)
CalTracs
The car is being built purely for street....mostly local roads and very minimal highway. I'm limited to 9.5CR because of bad gas in the area. Emphasis is on torque at low-to-mid RPMs.
I've been fiddling around with the Desktop Dyno and the best cam I could come up with is the CompCams XE274H (274/286, .519/.523). Anything else you can suggest?? Will the ~2500RPM TC be fine??
I also need suggestions on what rear gears to run. With the new build, something like 3.5 perhaps?? Remember....very little highway and only 30-40 miles at a time.
393w
9.5 CR
AFR 185/61cc
built C6
~2500RPM TC
25.8" tires
CalTracs
