Ok first off, the 302 i'm speaking of is the one in my sig, i've replaced all of the sensors except the tp, ect, act and iac....but I cleaned the iac, and the TP sensor seems to be getting proper voltage. The car runs very rich and dies out unless I keep hitting the throttle.
I've only checked the codes for KOEO because it wont stay running long enough to check them ER, but i'm not getting any.
I've checked the vacuum and I don't seem to have any leaks.
Timing is about where it should be.
First question, is there a ground down by the O2 sensors? Because I have a wire hanging loose down by the driver's side O2 sensor. The only thing I know I need to do is change the plugs because they are fouled.
Second, does anyone know the part number for a maf meter calibrated to 24 lb injectors? I want to make sure I didn't mix up the stock maf meter and my 24lb calibrated one.
Other than that any thoughts are welcome......and yea I looked through the surging idle checklist, up to page 7....I intend to get back on reading it now.
Thanks for any help guys
