Brakes Car Dives When Braking
  • Thread starter Thread starter darthcual
  • Start date Start date Oct 15, 2012
darthcual
985
Arlington, TX
Oct 15, 2012
  • Oct 15, 2012
So just as the title states. The harder I brake, the harder it dives right. Seems to me a few years back my buddies fox had this issue and it turned out to be a bad piston (sticking I think) in the caliper. Any thoughts or ideas?
jcgafford
1,114
95
104
Adrian, MI
Oct 15, 2012
  • Oct 15, 2012
re bleed the brakes? if it works great, otherwise i think you will be replacing a caliper or two.
darthcual
985
Arlington, TX
Oct 15, 2012
  • Oct 15, 2012
Your saying the cause might be air in the line? I have never touched the brakes since I've bought this car. But, I have had the wheels off and inspected them. They have plenty of pad and the rotors look brand new.
jcgafford
1,114
95
104
Adrian, MI
Oct 15, 2012
  • Oct 15, 2012
just a thought. can't hurt and if it is a fluid problem, or air problem, you just saved yourself having to replace calipers. my bet is a bad piston but i always try the "cheaper" test first.
Cory Berg
108
San Jose, CA
Oct 15, 2012
  • Oct 15, 2012
Air in the lines usually results in a soft/mushy pedal not a pull to one side or another. Sounds like you have a stuck caliper piston, so I would take apart that side caliper and inspect it. DO NOT press the brakes while the caliper is off the car. Bad things will happen.
Reactions: darthcual
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Oct 16, 2012
  • Oct 16, 2012
I think Pull is the standard definition for this condition. Dive is nose down on both sides and tail up. That would be suspension. When I re re read it, I agree with the brake issue. But if after the brakes are fixed it dives straight too far, it is time to check out shocks struts coils etc. Let us know how it gets fixed.
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
