Whats strange is sometimes it will idle perfectly than upon deceleration if I push the clutch in once it reaches around 1k it begin to idle search until the searching fluctuates so much the car just dies. However when it begins to idle search if I rev it to like 4000 in a quick rev the idle will return to normal and it won't idle search. Also if I decellerate very slowly, not pushing the clutch in until the car is at like 1200 then it won't idle search. I tightened every clamp and put teflon around the sensor IAC going into the pipe near the throttle body. I checked and I am only pulling the codes for fan and boost solonoid because I have neither hooked up. Running a gillis and I had a turbocoupe fan on there but the new intercooler piping gets in the way so I am going to have to run a flex-a-lite fan or something of the sort. Very happy with the quality of stinger's product! Someone mentioned you can adjust the idle by turning the allen in the VAM, is this correct?
