Car not running right
  • Thread starter Thread starter 1FatPony
  • Start date Start date Oct 15, 2006
1FatPony
241
  • Oct 15, 2006
So this morning I drove the stang for a little bit and it seemed to run fine. I fixed my 41 and 91 codes and tweeked the distributor and some other things. I just drove it again and it was bogging whenever I started off in low rpm. I dont think it was because I was in too high of a gear because it even did it while I was in first gear. I also tweeked my f'ed up ignition. The part where the ignition cylinder is broken so the cylinder doesnt stay in there. The first time I drove it I had it taped in the on position so the car would stay running. Then I found out that if you turned it to the on position and pulled it out while it was still in the on position the car would stay on. I did that the second time i drove it.
When it idles the engine seems to run fine.
My temp is also messed up. The first time I drove it it seemed to be okay. The second time I drove it the temp would rise rather quickly when I had it in gear (past the red mark to where i couldnt see the needle). When i pressed the clutch the temp would go down to about half way. I put it in neutral and pressed the gas and the guage didnt move. I also checked the radiator and there wasnt any pressure and it was full.
Whats wrong??
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Nov 14, 2026
Fox 5.0 Mustang Tech Nov 15, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech Today at 10:20 AM
Dakar09
D
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
