car still not starting.....help!!
  • Thread starter Thread starter jmd2914
  • Start date Start date May 24, 2005
J
jmd2914
937
Napa, California
May 24, 2005
  • May 24, 2005
alright, ive replaced my coil with a jacobs ultracoil, ive replaced my TFI ive made sure my fuel pump is priming before i try and start the car and the car still isnt starting. i can use any help that anyone has to offer cuz this is really starting to frustrate me. the car had an ignition system on the car when i bought it, that my brother actually put on, there is a box on the side of the engine bay that is supposed to boost the spark or something along those lines ( im a noob when it comes to electrical work on cars) would that have anything to do with why the car isnt starting? any help would be useful.
Joel
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
May 24, 2005
  • May 24, 2005
Does it have spark?
J
jmd2914
937
Napa, California
May 24, 2005
  • May 24, 2005
no, im not getting spark to the plugs
J
jmd2914
937
Napa, California
May 24, 2005
  • May 24, 2005
anyone have any ideas?
HISSIN50
34
129
May 24, 2005
  • May 24, 2005
will it start if you disconnect the box (running as if stock)?
good luck.
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
May 24, 2005
  • May 24, 2005
ditto that, at your coil you should have a grey plug that was unplugged from the coil and plugged into a jumper wire to the ignition box. Remove that cable and plug the plug directly into the coil and test for spark.
Jamie
Jaswir
578
Orlando, FL
May 24, 2005
  • May 24, 2005
try replacing the ignition module on the distributer
J
jmd2914
937
Napa, California
May 24, 2005
  • May 24, 2005
i replaced the ignition module, ill try bypassing the box
J
jmd2914
937
Napa, California
May 25, 2005
  • May 25, 2005
alright well i checked all my fuses and stuff and i played with the ignition box for alil bit and the car started for about thiry seconds, the idle was shaky and it died again, and wont start now, so any ideas with the new info would be helpful.
wyominghotwheel
156
Insanemustangs
May 25, 2005
#10
  • May 25, 2005
  • #10
your tps have power to it? check the green wire..........key on engine off..........should be in the .095 to .098 range.
hotwheels of insanemustangs
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 25, 2005
#11
  • May 25, 2005
  • #11
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
