CAR WON'T START!!!! HELP!
  • Thread starter Thread starter unistang
  • Start date Start date Jun 27, 2004
U
unistang
  • Jun 27, 2004
Just got the motor all together and ran into a major problem...THE DAMN THING WON'T CATCH. Sounds like its kinda tryin, but no dice. The only things that I can think of offhand that I did wrong are that I 1) have the wrong spark plugs (used the stock 302 plugs in a dart sr. head) or 2) tightened down the rockers too tight (went based on rocker play. I tightened them just until each rocker didn't have any play then another half turn). My setup is whats listed in my profile still. Anybody who knows what to try or lives on the southwest side of chicago and wants to help...lemme know.
thanks,
Nick
T
TheUser
1,859
Springfield, MO
Jun 27, 2004
  • Jun 27, 2004
Yout don't have a sig, so we don't know what you have. What exactly did you do? I think the plugs should be the same as stock plugs. May sound dumb, but check your firing order again - it goes counter-clockwise from 1. Sounds like maybe your timing might be off as well...did you set timing at all? If so, did you remember to pull the SPOUT (little plug by distributer)?
By the way, are your rockers pedestal mount or stud mount? If they're pedestal mount, you are supposed to get both valves closed - "0 lash" and torque 'em down to 22-26 lbs while counting the turns. If it takes more than 1 full turn to reach torque, then you need to shim that rocker. I believe Michael Yount said 1 shim is equal to 1/4 turn.
If they're stud mount, check out www.flowtechinduction.com and check out Ed Curtis' method.
Hope this helps
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 28, 2004
  • Jun 28, 2004
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the fuel injector red wires
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order from the non HO engines
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 29, 2004
  • Jun 29, 2004
9 times outta 10 the distributor is 180* off.
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
D
94 GT cold start takes a long time cranking. Help!
  • DeanS
  • Aug 6, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2024
ANY HELP IS APPRECIATED 1988 mustang gt
  • Foxbody1988
  • Dec 23, 2019
5K
Fox 5.0 Mustang Tech Dec 28, 2019
General karthief
N
Mustang 65 V8 won't start, no spark!
  • naika
  • Jan 9, 2019
4K
1965 - 1973 Classic Mustangs -General/Talk- Jan 14, 2019
naika
N
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
