Car wont start, please help!!!
Ok, well a few days ago when i went outside to start my car to go to school it didnt start. I knew it wasnt the alternator but i decided to change it anyways since i had a spare one. after i bolted in the new alternator the car started to my surprise. Well, i drove the car to work the next day but when i got off work the car didnt want to start. When i try to start it it cranks over (belt goes around pulleys) and stays at a constant 300rpm, has spark, good battery and alt, and people say if the starter is bad it wil make a choking/gaging sound - so it cant b the starter. Some one said it may be my fuel pump, another said it might be my ignition. Can someone please help?!?! Thanks in advance
well if it starts, then yeah, it's not the starter. Did you say it runs at 300 rpm...wow that's low. Does your fuel pump whine? They sometimes do that when they're going bad. When's the last time you changed your plugs? I'm kinda confused...does the car start or not?
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing. A Noid light available from Autozone, is one way to test the injector wiring. I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
A.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
B.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
C.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order form the non HO engines.
wow, lots of info. but anyways, the car did not start before, it just cranked over at 300rpm. But to day after work it magically started for me. i turned it off and tried to start it over and over and each time i did it, it started. what would be something that only works when it wants too? Whatever that part is needs to be replaced on my car.
check your battery ground...I just had this problem and replaced my whole starting system to find out it was a bad/not good enough battery ground. The battery cable should be grounded on the block in front of the oil filter on the same bolt that the starter wire holder bolts to. Also, there should be another smaller wire grounded on your fenderwell. You can see if it's bad ground by taking a pair of jumper cables, throw one black end on the neg battery cable and throw the other black end on the alt. bracket or something else grounded to the frame...if it starts, it's bad ground - this is what they told me to do and it worked for me. If that doesn't work, I guess start going through jrichkers list....
