car wont start
  • Thread starter Thread starter westridez
  • Start date Start date Apr 16, 2005
First Prev 2 of 2
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 18, 2005
#21
  • Apr 18, 2005
  • #21
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set emergency brake. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
In your case where the engine will not start when warm, I would dump the codes and look for ECT or TPS related problems.
jackchan
507
Mobile Alabama
Apr 18, 2005
#22
  • Apr 18, 2005
  • #22
I had the same exact problem on my 89 chevy truck.........turns out there was a temp sensor on the intake manifold that tells the computer what temp the engine is...........mine was stuck in the -130 syndrome.......otherwise it was pouring the heck out of fuel to it and flooding it. When the motor is kewl it has no problem starting as it needs a little extra, but when the thing would run for about 20 mins or so it wouldnt crank For NOTHING! worth a try, before I changed this sensor I changed , coil, fuel pump, fuel filter, ignition module, plugs, plug wires, dist cap, rotor, etc etc etc.............
hopefully yours will be bad as well.
NOT the one for the gauge but one that tells the computer what temp your engine is!
good luck
Jack
Thenemesis
321
chuckletown, sc
Apr 18, 2005
#23
  • Apr 18, 2005
  • #23
im with jrich... use the carb cleaner to get it to try and fire.. if its not firing enough to start then you have ignition problems (yeah im stuck on the ignition thing but had many bad problems before with it lol)
HISSIN50
34
129
Apr 18, 2005
#24
  • Apr 18, 2005
  • #24
in my experience, starting fluid works a lot better than carb cleaner when trying to get the car to start.
westridez
68
#25
  • Apr 18, 2005
  • #25
im gonna try starting fluid next time to see im also having this popping problem to out the intake mostly when its cold but if i flick the key on and off real quik it goes away but sometimes it comes back and im gonna change the air temp sensor like jackchan said since i have a spare maybe thats the problem i tired to pull the codes on it but could'nt seem to get it to work also today i was beating on it a bit i hit 4000rpms in 2nd gear and it popped out the intake and sputtered and a bunch black smoke came out the back only does it when its warm when its cooler it will hit 6000rpm with no problems
First Prev 2 of 2
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
