car wont start
  • Thread starter Thread starter importkiller90
  • Start date Start date Sep 16, 2007
I
importkiller90
59
iowa
Sep 16, 2007
  • Sep 16, 2007
any help would be great i go to turn the key on and the fuel pump will not turn off and car wont start i have 40 psi and there sounds like a leak from one of the injectors but i replaced all the o-rings on them any ideas would be great (also new fuel pump,new fpr, new fuel filter, new puter)
F
Fox8950
247
Sep 16, 2007
  • Sep 16, 2007
Does it fire/stumble at all? and also can you smell gas in the engine compartment like theres a leak? or do you mean you think the injector is hung open leaking fuel into the cylinder.
I
importkiller90
59
iowa
Sep 16, 2007
  • Sep 16, 2007
it doesnt want to do anything it just cranks if i spray starting fliud in the intake it will start right up and no i dont smell gas at all and i pulled the plug that i thought might be open and its dry as a bone
F
Fox8950
247
Sep 16, 2007
  • Sep 16, 2007
Kinda sounds like your fuel pump relay is bad to me but would love to hear some other opinions. Not sure if it cuts off injector pulse or something if it gets "stuck" in its prime loop.
I
importkiller90
59
iowa
Sep 16, 2007
  • Sep 16, 2007
anyone know how to check for injector pulse? i turned the key on and tested one of the injectors with my dmm and it said 12.5 vlts is that right?
HISSIN50
34
129
Sep 17, 2007
  • Sep 17, 2007
The injectors receive key-on 12 volts constantly. The puter pulses the ground to each injector to fire them.
I would check the self-test connector to ensure the FP relay's negative coil wire is not grounded (this feature is there to allow diagnostics so you dont have to cycle the key constantly).
Good luck.
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
how would i go about doing this? im new to the mustang scene so be nice
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 17, 2007
  • Sep 17, 2007
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 29-Jun-2007 to update TPS testing procedure for 94-95 Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
I
importkiller90
59
iowa
Sep 17, 2007
  • Sep 17, 2007
i have narrowed it down to something with the fuel injectors its not letting fuel into the engine and i still dont know where the sucking sound is coming from i sprayed them with soapy water and put my hand around one of the injectors and the sound was muffled so i replaced the o-ring and it still made the sucking sound i have no idea whats going on?
HISSIN50
34
129
Sep 17, 2007
#10
  • Sep 17, 2007
  • #10
How did you narrow down that it's the injectors?
I
importkiller90
59
iowa
Sep 18, 2007
#11
  • Sep 18, 2007
  • #11
what else could it be? the injector? the injector pulse? thats it right
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Sep 18, 2007
#12
  • Sep 18, 2007
  • #12
is there any residule fuel pressure? or after cranking does all of the pressure bleed off?
and you can use a noid light to see if the injectors are pulsing...
I
importkiller90
59
iowa
Sep 18, 2007
#13
  • Sep 18, 2007
  • #13
im going to go get a noid light when i get off of work and fuel pressure is aroud 35 or so when i crank her over
HISSIN50
34
129
Sep 18, 2007
#14
  • Sep 18, 2007
  • #14
If you don't have a noid light, you don't know that the injectors are even receiving power and ground pulsing.
We cannot emphasize enough the need to go through Jrichker's checklist. Make no assumptions and just run the list. It will save you time and money in the long run.
I
importkiller90
59
iowa
Sep 18, 2007
#15
  • Sep 18, 2007
  • #15
ok ill go through the list and see what happens
Methodical
1,192
11
59
Clinton, MD
Apr 1, 2008
#16
  • Apr 1, 2008
  • #16
What was the problem/fix?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
