Cast vs Alum....combustion characteristics
  • Thread starter Thread starter pistonhead
  • Start date Start date Mar 10, 2008
P
pistonhead
9
Edmonton, AB, Canada
Mar 10, 2008
  • Mar 10, 2008
Hello everyone. I have worked with both cast heads and alum heads. Besides alum being lighter, easier to do port work, and better heat sink are there any cons to running an alum head. I amthinking along the lines of the actual internal combustion only. Like does the lower melting point of aluminum matter? Does the softer metal effect drivetrain geometry? Does the expanding characteristics affect the way valves sit?
There is alot of questions here so I am looking for answers or even better would be some good resource material.
Thanks for reading
Sicarius428
2,085
Mar 10, 2008
  • Mar 10, 2008
Cast heads are actually better if you are trying to milk every HP compared to Aluminium... The heat dissipation is what soaks the HP too. On the flip side, Aluminium can run higher timing because they have less chance of detonation.
Kevin
dcurtis
688
Mar 10, 2008
  • Mar 10, 2008
Properly built you can run high compression on pump gas, just about 6 or 7 months ago I built a 12.3 to 1 chevy 350, it ran on pump gas all day long, it ran mid to low 9's in a 1000 foot. That engine is long gone already because my friend has a heavy foot and thought he could daily drive it.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Mar 10, 2008
  • Mar 10, 2008
Kevin
The basic principles of thermodynamics show that because cast iron doesn't conduct heat as well as aluminum, more heat energy is available for work production during the combustion process. But also, because aluminum heads will operate at lower average cylinder temperatures (because of its ability to transfer heat to the coolant better than cast iron), higher compression ratios can be used without detonation. So really, there isn't much to be gained using a CI head over aluminum, but its up to debate. The advantages of aluminum heads far outweigh what could possibly be gained from using CI, IMHO.
On the other hand, a lot of traditional hot rodders still run CI heads, but its more of a nostalgia thing than it is a power thing.
M
mastrdrver
82
O-Town, KS
Mar 12, 2008
  • Mar 12, 2008
No, since there is a thermal barrier that keeps the high combustion temps from doing any damage to the heads/pistons/etc. That is why an aluminum head looks like it has had a torch taken to the chamber when it has gone through preignition. The detonation creates a sound wave that knocks that thermal barrier away from the cylinder head.
It does not effect geometry since no valvetrain is anchored by the aluminum. It does not effect the valves since the seats are not aluminum and the valve guides are brass (I think).
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 12, 2008
  • Mar 12, 2008
Kevin
Exactly. If you have to absolutely identical heads and one is iron and one is aluminum the iron heads will make a tad more power because they hold the heat in the cylinders better. The trade off is obviously the weight. Also aluminum headed engines run hotter than an iron headed engine (although honestly i have no proof of this, it's just what i've always heard).
dcurtis
688
Mar 12, 2008
  • Mar 12, 2008
Personally I will always run iron heads, mainly because I'm not worried about the weight.
Fast63
717
  • Mar 13, 2008
I have heard aluminum heads make the engine run cooler because of heat dissipation.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 13, 2008
  • Mar 13, 2008
I've always heard the opposite because the fact that the heads are soaking up the cylinder heat is what makes the whole engine hotter, which requires more cooling. Iron heads don't draw the heat out of the cylinders. Aluminum heads transfer that heat right up into your intake also, more so than iron heads do. Think about a heat sink used on something like a computer processor...they're aluminum so they soak up the heat...the heads do the same thing with the cylinders which you actually don't want. Of course we're not talking about so much that it ruins the engine combo, all you need is a more efficient radiator and a good cooling fan and it'll keep things in check.
Again this is just what i've always heard over the years...it would be really cool to see a back to back dyno test of 2 identical cast heads and see how they make power and do temperature checks on both.
Fast63
717
#10
  • Mar 13, 2008
  • #10
Yeah, that does make sense. It would be nice to have that temp comparison... it's too bad no one ever has any articles on that sort of thing. Everything is about HP and torque and that's it. Not much science is explained
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Mar 14, 2008
#11
  • Mar 14, 2008
  • #11
If you really want to know, then go to college to be a mechanical engineer. That's what I'm doing.
There is a reason the best quality cylinder head designs on the market are aluminum, not cast iron…
Fast63
717
#12
  • Mar 14, 2008
  • #12
lol, already went to college to study criminal justice. have several mechanical engineers in the family though. I don't have time to take the classes but a simple article in a mustang mag would be nice.
squeak_cg
153
Lima, OH
Mar 14, 2008
#13
  • Mar 14, 2008
  • #13
Minor point, heat sinks don't exactly 'soak' up heat from electronics. The heat has to go somewhere and heat sinks enhance the heat transfer (or heat dissipation) to the ambient air by increasing the surface area. Sorry for the silly comment.
haha, this is coming from an ME
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 14, 2008
#14
  • Mar 14, 2008
  • #14
Yeah, that's still the same point i was trying to make. The heat source is the cylinder and the head just increases surface area and the heat dissipates through the heads...same thing.
The reason is that people want the light weight of aluminum and because aluminum is much easier and cheaper to cast and much easier to port...it has nothing to do with what i'm talking about. Like i said this is just minor details, it's not enough to sway people away from aluminum heads.
P
pistonhead
9
Mar 23, 2008
#15
  • Mar 23, 2008
  • #15
Thanks for the info guys. That really shows the combustion process from a different perspective than I have been looking at it previously.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
RANT!!! As A Blanket Statement.....all "forged" Pistons Are Not Created Equal
  • CarMichael Angelo
  • Nov 13, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2016
mikestang63
Good writeup on 4V heads
  • blackfang
  • Dec 20, 2007
  • SVT Tech Forum
2K
SVT Tech Forum Dec 20, 2007
blackfang
M
2011 V6 stang official release
  • master_V12
  • Nov 29, 2009
  • 2010 - 2014 Specific Tech
  • 2 3
13K
2010 - 2014 Specific Tech Dec 12, 2009
SS02
I found this for people that has a supercharged 5.0 mustang
  • mustangfan1990
  • Feb 24, 2008
3K
Fox 5.0 Mustang Tech Feb 25, 2008
mustangfan1990
