Ceramic coated headers
  • Thread starter Thread starter mikehuyck
  • Start date Start date Sep 6, 2006
M
mikehuyck
9
Nebraska
Sep 6, 2006
  • Sep 6, 2006
Hello all,
I want to buy some nice looking shorty headers for my 64 1/2 coupe (preferrably ceramic or nickle plated). It will have a 302 w/AOD. Just wondering what you guys have used or would recommend. Seems like Jegs and Summit don't list anything specifically for clasic mustangs, and I am worried that if I just buy any header for a SBF I will run into clearance problems. Right now the car doesn't have exhaust, so don't have to worry about mating up to anything existing... Any help is appreciated!
thanks,
MIke
68torinogt
Hey guys, guess what--I have a bi-pass!!!
Mar 21, 2006
Welcome my son, welcome to the machine
Sep 6, 2006
  • Sep 6, 2006
they are worth the money
geostang351
946
Danb., CT
Sep 6, 2006
  • Sep 6, 2006
What is worth the money?
R
Robdogg67
148
Seattle/Tacoma, WA
Sep 6, 2006
  • Sep 6, 2006
I would recommend FPA longtube headers as none of the other big names will have a solution. FPA headers are very well built, have ceramic option, excellant ground clearance and likely will be the last header you'll buy for that car.
I have FPA longtubes on my 302/AOD with Magnaflow X-pipe system.
68torinogt
Mar 21, 2006
Sep 6, 2006
  • Sep 6, 2006
o hes looking for headers
i guess it would help to read it rather than skim it
65frank
20
Lake Ridge Virginia
Sep 6, 2006
  • Sep 6, 2006
I have a 65 coupe with 302 & AOD and use the hedman elite shorty.
Fit is good.
They have been on about 1 or 2 years (daily driver) and So far they still look good.
None of the long tube I tried would clear the AOD.
AdamInChains
128
  • Sep 6, 2006
I have a 347 stroker in mine with an AOD, and i also run the Hedman Shorties. Not much room for anything bigger. These seem to work great so far.
C
chromedog
554
worlds center for speed
Sep 6, 2006
  • Sep 6, 2006
go to hedmans website, and find the headers to fit your car (elites are worth the extra money) then, either call, or go to summits website, and check the numbers... i went through this same deal 2 months ago, they stock alot more than the catalog shows...
M
mikehuyck
9
Nebraska
Sep 6, 2006
  • Sep 6, 2006
Thanks guys! I checked Hedman's site and looks like the Elite for my car is part #88408. Also did you go with the Thermal or ceramic coating? From the pictures, I can't see any difference.
Max Power
1,774
St Paul
Sep 7, 2006
#10
  • Sep 7, 2006
  • #10
I have the elite coated hedmans too. I like em a lot.
Call your Hedman tech rep and ask him.
jcode68
892
Massachussetts
Sep 7, 2006
#11
  • Sep 7, 2006
  • #11
A StangNet member (sorry, don't recall his name to give him props) created a header fitment database specifically for classic Mustangs. Here is the link:
http://www.stanginfo.com/Headers/headeroptions_view.php
Also, you should think a little bit ahead about other mods you have planned for the car to avoid beating your head into the wall later. For example, if you are planning a T5 or other transmission swap, the clutch mechanism options have header fitment considerations. Another example is rack & pinion conversions will only work with specific headers. Ceramic coating is a worthwhile option (I did it) but is expensive. You don't want to have to toss them 8 months from now to do that R&P swap you had planned.
M
MitchGT
204
Sep 9, 2006
#12
  • Sep 9, 2006
  • #12
shorty headers would help with a rack and pinion later on, if that's in the plan. Long tube headers and R&P don't play well together. Worse yet, my long tube headers are ceramic coated, had to be cut and rewelded, and are now in the process of being recoated. You might want to get the headers, assess the fit issues, then get them coated.
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
