Changing the fluids this weekend...
  • Thread starter Thread starter Unreal281
  • Start date Start date Mar 5, 2007
Unreal281
98
  • Mar 5, 2007
I have been running mobil 1 full synthetic for quite some time now...and when I break my car out for the spring this weekend...i'm going to need to change the fluids again.
Currently I am running 5w30
I am thinking about switching over to 5w30 royal purple...
any suggestions???
how is the lineup of tranny/rear fluids???
thanx
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 5, 2007
  • Mar 5, 2007
Mercron V is best for an auto, it's synthetic and our tranny cant desipate heat for a damn
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 5, 2007
  • Mar 5, 2007
for oil i woudl only really consider, Mobil 1, German Castrol(0w30), Redline or Amsoil.
Mobil 1 ATF is Mercon V approved.
Unreal281
98
  • Mar 5, 2007
Its a 5spd...mybad
Unreal281
98
  • Mar 5, 2007
How many quarts are needed to change the manual tranny fluid???
How about the rear axle fluid???
Anything else i should buy while i'm at it?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 5, 2007
  • Mar 5, 2007
you have to take of fhte diff cover to change the fluid. you will either need a tube of RTV or a gasket from a parts store. they do make gaskets, i know that NAPA carries them as well as CarQuest.
SilverBullet00
1,150
Wichita, KS
Mar 5, 2007
  • Mar 5, 2007
For the T45 I think its like 3.2-3.5 qts (you will need to buy 4 qts no matter what). And Mobil 1 is damn good, I wouldn't switch. Royal purple is great, don't get me wrong, but you generally have to order it @ ~$6 /qt plus shipping which can get expensive. I can go to walmart and buy a 5 qt jug of mobil 1 for 22.99 + 5.25 for an extra qt + 2.99 for a motorcraft oil filter and be done with it.
40th GT
916
Lawrenceville, GA
Mar 5, 2007
  • Mar 5, 2007
Agreed.
Use a 80w-90 for the rear end. Synthetics are always good. You should consider flushing your brakes and radiator also, if you haven't done so already.
Unreal281
98
  • Mar 6, 2007
Yes...mobil 1 IS damn good...but I went out last night and purchased my 6 quarts of 5w30 royal purple, and a motorcraft filter...and it was worth EVERY penny of it...
The car actually feels like its running PERFECTLY as it should...I'm never going back to any other synthetic...
Are those the right Fluids i should be buying for the rear gears and tranny fluid???^^^^ Also...will i need a friction modifier or no???
I'm also going to try out the "purple ice"....I'm MORE than impressed with this stuff...
:SNSign:
Skidawg
104
#10
  • Mar 6, 2007
  • #10
Mobil1 is not what it used to be. They changed base stocks and now the oil is of similar quality to most every other major brand synethic (and about $1.50 more a quart). As it stands now, Mobil1 is just a regular synthetic.
I don't know enough about Royal Purple motor oils to help. I've heard mixed reviews about it. I do know they're gear oils perform very well.
Amsoil has always been a great choice in oil. It's not as pricey (relatively speaking) as it used to be and the they're oil filters do extremely well in the tests.
The weight you're running is fine. You can go 5W-20 or 5W-30 and the engine will run fine. As long as you're not running anything exotic on it and changing your oil at reasonable intervals, you'll be served well by any "normal" synthetic.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 6, 2007
#11
  • Mar 6, 2007
  • #11
ya i have been dissapointed by M1 changing to a Group 3 basestock instead of using a PAO base stock. i still have a stash of M1, about 30 quarts, but and slowly building a stash of GC, i have about 12qts of that, but its so hard to find.
i love that both my cars take the same filter, i have a 2000 grand marquis also, so i have a ton of FL-820s filters. i go to Wal-Mart and buy them out, which isnt often considering the closest ones are 50 miles away.
Unreal281
98
#12
  • Mar 7, 2007
  • #12
:SNSign:
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
