  • 1994 - 1995 Specific Tech
charging problem?
  • Thread starter Thread starter jtb19nh
  • Start date Start date Dec 2, 2005
jtb19nh
156
Dec 2, 2005
  • Dec 2, 2005
i have a 95 gt. when i turn the key to the on position the battery meter looks like it is at around 10 volts. when the car is on and idling the volt meter drops to the same position as when the key is in the on position. when i hit the gas the volt meter jumps right up to the middle. i have replaced the alternator with a 200 amp unit and i still have this problem also put a yellow top in. any ideas where to start to look for the problem?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 2, 2005
  • Dec 2, 2005
Simple test. Hook a DVM to each of the battery terminals. Record the voltage with the car off. Record it then again w/ the engine running.
If the voltage is higher, then the alternator/regulator is working likely.
Next pop the vent caps to the battery. Make sure the water is full in each cell, up to the bottom of the plastic case. You dont want it to be flush with the top of the holes, that's overfilled. So with the engine off, put neg. test lead to the neg at the battery. Then stick the pos. test lead in the water of the first cell closest to the neg terminal. You should read 2.2V. Then go to the next cell, and you should read 4.4V, etc etc.....
Each cell is ~2.2V, and the are wired in series, so each cell adds 2.2V to a total of 13.2V or so on a fully charged battery. Now if one cell doesn't add any voltage to the total count, you have a bad cell.
Another thing to mention, with the car running , measure the voltage at the battery. Should be initially 14.4 or so, then drop down slowly. Once it reaches around 13.6 or less, turn the car off. Then measure the voltage again. It should be slightly less, but maintain above 13V for a while. If it drops down drastically, it's not taking a charge. maybe the acid is gone, or something. Bad battery, time to swap.
note: this should be done with all loads off. That includes the dome light and the hood light. No amp draws should be present, that includes your stereo and such.
Scott
HGFireHazard
460
Michigan
Dec 3, 2005
  • Dec 3, 2005
Do you have any kind of system in your vehicle? When you upgraded your alternator did you run larger wire as well? Other than that the post ^^^ should have covered everything else.
Methodical
1,192
11
59
Clinton, MD
Dec 3, 2005
  • Dec 3, 2005
Yeah did you upgrade the wire between the battery and alternator. I have the 200 amp alternator and I upgraded to the 4 gauge wire - if my memory is correct - which also came with a larger fuse - again if memory is correct. Either way get rid of the stock cable if you have not done so.
Peace
Al
BPA
159
S.F.
Dec 3, 2005
  • Dec 3, 2005
Check our battery ground cable as well.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
