  • 2005 - 2009 Specific Tech
check engine lights
  • Thread starter Thread starter kfddakota
  • Start date Start date Aug 29, 2005
K
kfddakota
28
temple, texas
Aug 29, 2005
  • Aug 29, 2005
anyone know a link that shows what the check engine light numbers correspond to? Im throwing 2196 and 2198. Id appreciate any help yall may have.
pumpkinfish
23
Philly Area
Aug 29, 2005
  • Aug 29, 2005
I got these codes from Diablosport webpage http://www.diablosport.com/FordDTC.php#Ford Diagnostic Trouble Codes
enter them as p2196, so on and so forth.
HO2S11 not switching correctly. Sensor indicates rich.
Low Manifold Vacuum on TMAP systems only.
High Fuel Pressure
This DTC may be caused by :
Air intake restriction
O2 Sensor Signal Stuck Rich - Bank 2, Sensor 1
Suspect HO2S21.
Dirty air filter.
High fuel pressure.
Damaged fuel injector.
Suspect PCM.
K
kfddakota
28
temple, texas
Aug 29, 2005
  • Aug 29, 2005
thanks man for the help
K
kfddakota
28
temple, texas
Aug 29, 2005
  • Aug 29, 2005
i tried that earlier today but nothing showed up. Only because i forgot to enter the p before the code.
169stang
89
South Florida
Aug 29, 2005
  • Aug 29, 2005
What mods do you have and what have you done to it lately? Anything unusual happen lately besides the CEL. Any service work? Check to make sure the A/C is not draining directly onto the 02 harness which is zip tied to the side of your tranny. Your best bet is to take it to the dealership and let them hook it up to the computer. They can pinpoint where the issue is coming from. Worse case scenario, you'll need a new wiring harness. Yes, that means all new wires. I know someone that has gone thru 5 until he had one that worked. Alot of time at the dealership!
JTGrant
775
GA
Aug 3, 2006
  • Aug 3, 2006
any update?
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
