  • 1994 - 1995 Specific Tech
Checking O2 sensors with a voltometer?
  • Thread starter Thread starter The Green GT
  • Start date Start date Mar 4, 2007
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 4, 2007
  • Mar 4, 2007
How do you do it again? Its not for my Mustang, its for a buddy.
HISSIN50
34
129
Mar 4, 2007
  • Mar 4, 2007
Your buddy has an exhaust gas sensor installed on him? And you want to check it?
When I check the O2 voltages in real time (car running), I simply gain access to the O2 signal wire for the side I'm testing. This can be done in the kick panel where the EEC harness connects to the computer or at the O2's connector. If doing the latter, I'd recommend a jumper harness so you are not lying underneath an idling car. The kick panel might be the easiest.
Put the meter on the scale that encompasses one volt (often 5 volts) and watch the meter. It should quickly go from ~0.05 to 1.0 volts (+/- a little bit) at least once a second, if not faster.
Good luck.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
