Cleaning Fuel System
  • Thread starter Thread starter Danny-Boi
  • Start date Start date Jun 25, 2004
Danny-Boi
97
  • Jun 25, 2004
I was reading about this stuff that comes in a pressurized can that you hook up to the fuel line instead of the fuel pump...not sure if thats correct. My question is where exactly do you connect the can? I read its in the trunk somewhere. Any help would be great.
Thanks, Danny
88stangmangt
2,332
Stafford,VA
Jun 25, 2004
  • Jun 25, 2004
where i work we do a fuel system treatment and how we do it is dump a bottle of fuel cleaner into the tank. then we dump intake cleaner into a pressure bottle and put a air hose on the unit turn the air valve on high put it on the vaccum hose from the brake booster the start it up. we use a go pedal stick(a adjustable stick that holds onto the wheel and pushes down on the gas pedal and hold's it at 1500k)then let it do it's thing then after it has used it all we rev and hold it at 3k and let all the thick carbon flow out.(cars with over 100k are fun to watch because it looks like they are on fire!!!!)
04sleeper
2,674
14
89
Dallas, TX
Jun 25, 2004
  • Jun 25, 2004
Thanks, Danny
You are correct about pressurized cleaner in a can. Ford used to use it to clean injectors. It hooks up to a hose that screws onto your Schrader Valve. You then have to kill the fuel pump by unplugging the relay under the seat or unhooking the inertia switch in the trunk. Then you open the can and start the car and let it idle. You don't rev it up! Just let it idle. It will run for a few minutes off the can and then stall out when it is done. Then you hook back up your relay or switch and thats it. I have done it before and it seemed to work ok. But I have new injectors now so......
MadMatt5oh
441
St Paul, MN
Jun 25, 2004
  • Jun 25, 2004
where would one buy such a cleaner? Whats the item description? This sounds like something I need to do badly
04sleeper
2,674
14
89
Dallas, TX
Jun 25, 2004
  • Jun 25, 2004
Ford used to sell it. I haven't done it in quite some time now so I'm not sure if they sell it anymore. I borrowed the hose from a friend that used to work at Ford to do mine.
Danny-Boi
97
  • Jun 26, 2004
Hmmm i will have to find out where to buy this stuff...
88stangmangt:
How much does it cost to have that done?
Thanks
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
